Sup yaa I have a AudioControl Series II EQL Forsale or Trade
I am looking for $100 or trade.
Prefer any one of these :
7" lilliput touch screen
Opus 150
list your offers
Here are the specs for the AudioControl:
AudioControl is probably best known for their great equalizers and crossovers, and the EQL is one of the reasons why. AudioControl pretty much wrote the book on "EQ-ing" your sound system, and the EQL works wonders with any 2-channel audio system even factory headunits! The EQL is a 2-channel, 13-band, dual-bandwidth equalizer with level matching circuitry to allow for either speaker-level or line-level inputs. The EQL also features a high voltage PWM power supply for increased headroom and noise rejection, and a built-in Programmable Frequency Match (PFM) subsonic filter to protect your speakers and avoid wasted amplifier power. Made in the USA; White in color.
Frequency Response: 10-20,000 Hz
Total Harmonic Distortion: 0.005%
Signal to Noise Ratio: 110 dB
Maximum Input/Output: 9.5V (Speaker or Line-Level Input)
Equalization Boost and Cut: 12 dB
Dimensions: 8 7/8 W x 6 7/8 D x 1 1/4 H
Shipping Weight: 4 lbs
HALF OCTAVE BASS EQUALIZER six half-octave bass equalizer controls for each channel with frequency centers at 31.5, 45, 63, 90, 125, and 180 Hz.
OCTAVE EQUALIZER seven full octave equalizer controls with frequency centers at 250 and 500 Hz; and 1, 2, 4, 8, and 16 kHz.
INPUT GAIN variable gain controls to adjust Left and Right Input levels.
OUTPUT LEVEL CONTROLS output attenuators for Left and Right Outputs.
INPUT MAXIMIZED indicator for setting the proper input gain. When this light flickers you have juust the right amount of input gain.
2 VOLT OUTPUT indicator for monitoring output level to detect and set a 2 volt level.
POWER indicator confirms power is reaching the EQL.
The front panel contains power and input/output connections, as well as an equalizer bypass button
HIGH LEVEL INPUT Our handy plug for connection of speaker outputs from a
deck or factory stereo.
EQUALIZE IN/OUT Press in to engage the equalizer settings on your EQL.
LINE LEVEL INPUT RCA jacks for connection of low-level stereo signals from a head unit.
OUTPUT RCA jacks for connection of EQL outputs to the inputs of an amplifier.
REMOTE/+12/GROUND - Another handy plug for power connections of your Remote Turn-On lead, +12 Volts, and Power Ground.
