I have a brand new, never opened or used Syntax S635MP motherboard with a 1.3GHz VIA Sameil2 C3 Processor. I'm also including a stick of brand new, never opened, 128MB DDR PC2100 ram.
Here are the motherboard specs:
133MHz FSB
1.3GHz Samuel2 C3
Memory Support:
2 184 pin DDR sockets (2 X 512MB 266MHz Max)
Expansion Slots:
1 CNR Slot (With 56k Modem Included)
2 32bit PCI slots with PCI 2.2 Compliant bus interface.
On-Board IDE Channels:
2 IDE Channels (Up to ATA100)
Built in high performance 256bit 3d/128bit 2d engine
Support AGP 2.0 Compliant config setting
Supports AGP 4X 266MHz with 16 stages pipeline full side band/pipe function
AC97 Codec:
16bit stereo full duplex codec with fixed 48KHz sampling rate
3 analog line level stereo inputs with 5bit volume control
Built in 10/100 Ethernet LAN
Onboard I/O Ports:
2 PS2
1 serial
1 vga
1 parallel
Maximum 6 usb 1.1 ports. 4 back panel ports
Audio jacks
mATX form factor (244mmX200mm)
Still comes in original box.
Box includes:
Ribbon IDE cable
Ribbon Floppy cable
CNR 56K v.90 Modem
I/O Back panel for Case
128MB DDR PC2100 DIMM (Sealed)
Price is $100 + Shipping to Continental US. Might ship out of US.
Paypal: [email protected]
