5 Attachment(s)
FS: Xenarc 700-IDT & 16-ft Cable - BRAND NEW!
Xenarc 700IDT In-Dash 7" VGA Touchscreen
Updated Price!
SOLD!!!! Thanks ppl!!
This has been an incredible unit. Don't go for the immitation - go for the real thing and get a Xenarc. This is Xenarc's in-dash 7" touchscreen unit. It's basically a Xenarc 700TSV in an in-dash case with the high-brightness upgrade.
As you can see in the pictures, the unit is brand new and has never been installed (the plastic cover is still on the screen and there are no cosmetic marks on the unit). I would also like to mention a little known fact about the 700IDT's, if you remove the black plastic faceplate, there is an empty cavity directly below the screen which is nearly the size of a slimline slot-load dvd/cd drive. There is enough space for one of these drives and it would require very little modding in the back of the unit to make space for the USB/power lines. I haven't tried this, but if I had an available slot-load drive, I would do it in an instant. I received this unit from Xenarc as a replacement to an older unit. They don't have any parts for the 700IDT's because they were recently released and they replace the whole unit with a new one.
The warranty is still valid on this unit until August 2006 and I am including the $45 16-foot Xenarc cable.
Quote:
Originally Posted by Here is the 411 on the unit...
-For In-Car Computing, PC, Server, GPS, and various VGA Use
-1-DIN In-Dash, heavy duty construction
-Spring loaded, automated mechanical flip-out design (Non-Motorized)
-Left and Right swivel
-4-wire resistive Touch Screen (USB)
-Multi-Monitor Touchscreen Support
-VGA Input x 1 & Video Input x 2
-Audio Input / Built-in Speaker
-NTSC / PAL Multi-System
-16x9 Aspect Ratio
-High Resolution Display - up to 1600 x 1200
-Auto detects 800x480 resolution
-Upgraded High-Brightness CCFL
-Adjustable backlight level for night-time use
-Pixelworks High Performance Video and VGA Processor
-High Quality Scaling & Anti-Aliasing
-Auto power-on upon signal detection
-Automatic display adjustment
-On Screen Display Control
-20-Pin heavy-duty connector
-Anti Glare Coating
-Supports 11V DC ~ 24V DC
-"E" Mark Certified for Automotive use
Specifications:
-Screen Size: Diagonal 7" (16:9)
-Physical Resolution: 800 (H) x 480 (V) WVGA
-Supported Resolution: 640 x 480 ~ 1600 x 1200
-Dot Resolution: 2400 x 480 = 1,152,000 (dots)
-LCD Brightness (w/o Touchscreen)*: 400 cd/m²
-Display Brightness (w/ Touchscreen): 300 cd/m²
-Touch Screen Interface: USB port
-Operating Voltage Range: DC 11V ~ 24V, 1A
-Power Supply: DC 12V
-Power Consumption: <8W
-Operating Temperature: 23°F ~ 158°F
-Dimension: Standard 1-DIN
-Weight (lb): 1.28
-FCC, CE, E13 Certification
-18 Month Warranty
-No dead Pixel Guarantee
This sale includes the : 700IDT In-dash unit, 16-foot Xenarc cable, mounting sleeve, 12-volt DC adapter, 4-pin harness and original box.
$425 + $15 FedEX/UPS insured ground shipping to continental US.
I will accept payments via Check, Money Order or Paypal (NON-CC, BANK ACCOUNTS ONLY). If you wish to pay by Credit Card, you will have to cover the Paypal fees which will be approx. $14. If paying by check or money order, it will have to clear my bank prior to shipping.
I am a very reputable member of these boards and of ebay (username hd04) and will work to make this a smooth transaction. Thank you and PM me with any questions.
