Memphis stuff is def hot, and top notch, I have a 1000D and a 4 channel from them, and they push. But i paid $500 for both my amps, 1100 watts, and 75x4. $525 is a lil much... eBay might get u a better closer amount. Just my 2 cents
Both items have never been used.
"The MCH600 provides four 55 watt channels and a 400 watt @ 1 ohm 5th channel. Built in crossovers feature a selectable 12dB or 18dB per octave slope, and are fully variable from 40-6kHz. This makes bi-amping separates a possibility when no rear channels are used.
Channel 5 has a fully variable low-pass crossover, a sub-sonic filter and an optional wired remote gain control (16-MCRG)."
* Mica-Filled Polypropylene Cone
* Unique Cone Stiffening Rib
* Unitized Concave Dust Cap
* Rubber Uni-Surround with Integral Mounting Gasket
* Hyper-Extended Pole Piece
* Bumped & Vented Back Plate
* Optimized for small sealed or ported enclosures
Subwoofer Specifications
Rec. Sealed Box Dims: 0.55 - 1.00 cu.ft.
Rec. Ported Box Dims: 1.00 - 1.50 cu.ft.
Free Air Usage: not recommended
Sensitivity: 90 dB
Frequency Response: 10-150 Hz
Recommended RMS Power: 350W
Peak Power Handling: 700W
Impedance: dual 2 ohms
I paid $160 for the sub, and $600.00 for the Amp.
I'd like to get $130 + Shippin on the sub, and $525 + Shippin & Paypal fees for the amp.
Still for sale. Entertaining offers.
