Here -
How To Fit - Its Easy
1. Unclip the panel surrounding the heater controls.
2. Remove the two screws at each end of the U shaped plastic trim above. Pull the framework out.
The CD version and cars fitted with climate control. will have a one piece veneer trim that is merely clipped in place.
3. Insert the longer arm with the grips underneath the vent assembly and hook the other arm under the lip of the console fascia.
4. Refit the trim and fascia.
NB The bracket can be fitted anywhere along the horizontal.
No Reserve !!!
