Results 1 to 10 of 18
Thread: FS: Pioneer 4 Channel Amp GM-4000F
    May 2004
    For sale is a like new Pioneer GM-4000F
    It is in like-new condition, been used for about 4 months.
    Asking 75$ OBO.
    Plus shipping.
    Pm me for pics.
    The super-efficient GM-4000F amplifier dishes out 300 watts of peak music power & can be configured for 2-, 3-, or 4-channel operation. Its pulse width modulation (PWM) circuit efficiently outputs only the lower frequencies, which makes it ideal for powering a sub or two. The selectable high-pass & low-pass filters give you flexibility for your system, & the 4-channel speaker level input offers added control. Oversized screw-type power/ground terminals & RCA in/outputs are provided. * Peak Music Power 300 Watts * Number of Channels 4 * Load Impedance Capability 2~8 Ohm (Stereo), 4~8 Ohm (Bridged) * Continuous Power (4 ohm) 35W x 4 * Continuous Power (2 ohm) 40W x 4 * Continuous Power Bridged (4 ohm) 70W x 2 * Frequency Response 10Hz ~ 50kHz * Total Harmonic Distortion 0.008% * Signal-to-Noise Ratio 100dB * Dimensions 12" x 2-3/8" x 9-3/8" * Bridgeable * Channel # Capability 2/3/4 * PWM Regulated MOSFET Power Supply * Screw-Type Speaker Terminals * Balanced Isolator Input Circuit * RCA Inputs 4 Channel * RCA Outputs (Pass Thru) * Speaker Level Input 4 Channel * Input Level Control Hi-Volt (400mV ~ 6.5V) * Built-in Crossover Selectable HPF/LPF (80Hz, -12dB/Oct.) (Front/Rear Independent
    May 2004
    bump
    bump
    Maximum Bitrate DJiK's Avatar
    Apr 2005
    Los Angeles (Winnetka), CA
    Quote Originally Posted by bigvalboa
    Does that mean I can connect it to 2, 4, or 8 Ω speakers and not worry about overloading/underloading the amp?
    Can I select a high pass for tweeters (one pair ~ 2 channels) and a full pass for my 3-way speakers (also one pair)?
    Could you PM me some pics?
    Where are you shipping it out of?
    --Thanks!
    For Sale: Carputer (CarPC) & RCA Y-Adapter
    Newsflash: Take a look at my unsold stuff above, thanks!
    Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
    May 2004
    Quote Originally Posted by DJiK
    --Thanks!
    yeah the amp should work fine for that..it does have low and high pass...i am shipping from chicago...only pic i got right now is
    http://www.nmatese.com/subpics/IMG_0013.jpg
    it is obviously the black amp.
    Jan 2006
    Was this amp sold?
    May 2004
    still got it
    Newbie UrbanSoot's Avatar
    May 2006
    West Hollywood, CA
    where are you located?
    May 2004
    just outside of chicago...can ship no problem tho
    May 2006
    West Hollywood, CA
    how much is shipping to 90046?
    May 2004
    15-20 at most. ill cut ya deal though
  1. FS: Clarion 4 channel amp
    By snmnetwork in forum Classified Archive
    Last Post: 11-07-2005, 03:07 AM
  2. Replies: 7
    Last Post: 10-18-2005, 02:53 PM
  3. Pioneer DEH-7500 and Directed 5ch amp
    By ummagawd in forum Classified Archive
    Last Post: 10-16-2005, 09:16 PM
  4. 2 channel amp to 4 channel SPs
    By zvi in forum General Hardware Discussion
    Last Post: 02-17-2004, 10:46 AM
  5. Looking for opinions on Alpine MRV-F450 5 channel amp
    By ShinkunoNamida in forum General MP3Car Discussion
    Last Post: 09-20-2002, 05:57 PM
