Results 1 to 8 of 8
Thread: Fs: HD TV 34'
    Low Bitrate amdpro's Avatar
    Nov 2005
    Texas
    Fs: HD TV 34'
    HD34-300 34 inch HD TV $$579+ Shipping Looking for local sale if possible
    Technical Aspects
    34" (Diagonal) Flat Screen 16X9 Direct View HDTV Monitor
    Supports HDTV standards 480i, 480p, 1080i, (Progressive and Interlace scanning) NOT 720p or 1080p
    Autoformat
    Automatically detects and adjusts the TV according to the screen format for each channel. Autoformat is only available on 480i SD pictures on Component 1 & 2 inputs.
    Auto Tuning
    Once your HDTV monitor and DISH Network satellite TV receiver are connected with a DISH DVI cable, press the SAT button and the monitor and satellite receiver will begin displaying satellite programming. After the monitor is on, pressing the SAT button will always switch the display to satellite programming.
    Commercial Skip and Picture Freeze
    With commercial skip, a countdown timer returns your TV to the original channel, so you can "surf" through other channels during program breaks. Picture Freeze captures the current image frame and displays it on the TV screen. When you unfreeze the picture it will return to current 'live' programming and not continue on from the selection.
    Contrast Expand
    Adjusts the contrast of the picture according to the light in the room.
    Digital 3-line comb filter
    The comb filter helps to separate color signals from black and white, providing a sharper picture. Of the three types, the 3DYC provides the sharpest picture, then the digital (2-line or 3-line) comb filter, then the analog.
    DISH DVI-HDTV Input
    DVI (Digital Visual Interface) is a digital video connection between HD receivers and supported HDTVs. This type of connection provides a high quality image and no quality loss due to the fact that all signals are purely digital. DVI does not include Audio. This is the default input setting on the monitor.
    Dolby Virtual
    Available only for stereo signals. Creates a virtualized surround sound experience from two speakers using the Dolby Pro Logic decoding. It provides the sensation of being surrounded by additional speakers.
    Dual speaker stereo and Virtual Dolby with dbx Noise Reduction
    External speaker connections and Subwoofer outputs
    Front Panel Connections
    The monitor has front panel connections for your convenience. These connections may be located on the left-hand side of the monitor. Note: Do not try to use the S-Video and RCA Video In at the same time because the two signals interfere with each other.
    Fully controlled by Dish Network 8.0 UHF Pro remote
    One-Touch Satellite Viewing
    Once the HDTV monitor and HD Receiver are connected with a DISH DVI cable, pressing the SAT button on the 8.0 UHF Pro Remote Control will turn on the receiver and monitor and select the DISH DVI input.
    PIP (Picture-In-Picture) and POP (Picture-Outside-Picture)
    Description: PIP lets you watch two channels at one time - one channel on the main screen and the other in a smaller window. POP also lets you watch two channels at one time- one channel on the left side of the screen (the main picture) and the other on the right.
    Requirements: Press the PIP button to bring up the PIP window. Press again to bring up POP.
    Note: PIP and POP are NOT available while viewing HD programming.
    Scan Velocity Modulation (SVM)
    Improves picture sharpness in the transitions between dark and light areas of the TV screen.
    Sleep and Wake Timers
    Sound Logic™ Audio Leveling
    Automatically adjust the picture volume to tone down blaring commercials.
    V-Chip Parental Controls
    Description: You can block programs and movies by content, age-based ratings, and/or movie ratings. TV Parental Controls are not available for DISH DVI, Component 1 or Component 2 inputs. On these inputs, the satellite receiver would provide the programming limits.
    Requirements:
    Set up the Parental Control menu in the TV's main menu.
    The broadcasters must use the rating system when they send the program to your TV in order for your TV to block the program.
    Parental controls must be locked for these settings to take affect.
    Video Noise Reduction
    Used to reduce picture "static" especially useful in providing a clearer picture for weak off-air signals. Video Noise Reduction is only available on 480i SD pictures on Component 1 & 2 inputs.
    Power supply draw: 230W
    Connectivity
    (1) DVI-HDTV/DISH DVI input (HDTV)
    (2) Set YPrPb High-definition Component inputs (HDTV)
    (2) Set RCA-type audio/video inputs
    (2) S-Video input (SDTV)
    (1) TV antenna/cable input (capped), black F-connector
    (2) Set RCA-type audio/video outputs (SDTV)
    (1) Set External Speaker output (8 Ohm, 15 watts max. speakers purchased separately)
    3-prong power cord
    (1) S-Video front panel input
    (1) Set RCA-type audio/video front panel inputs
    (1) Headphone Jack 3.5mm stereo
    Nov 2005
    Texas
    Price 500.00 plus shipping bumpity just in time for Super bowl
    Falls Church, VA
    Is this the same television Dishnetwork was selling in 2004? It was a bundle with the receiver, remote, cable and television? Are you selling the whole bundle at that price? I remember they were going for <$600 to existing dishnetwork members.
    This thing Weighs 170 lbs!!
    Nov 2005
    Texas
    Its just the Tv
    Variable Bitrate AllThingsEnd's Avatar
    Jan 2006
    Ft. Bliss, TX
    where in texas are you. im in el paso
    Nov 2005
    Texas
    Im in Dallas
    Falls Church, VA
    no remote either?
    Nov 2005
    Texas
    Tv comes with a remote
  1. Replies: 1
    Last Post: 12-03-2005, 09:58 PM
  2. FS: TV Wonder (tv tuner)
    By wizardPC in forum Classified Archive
    Last Post: 05-10-2005, 01:48 PM
  3. FS: XBOX Package w/game, 40gb USB2 HD, DC-DC PSU, PCI Radeon & more
    By CrazyLittle in forum Classified Archive
    Last Post: 02-21-2003, 04:12 PM
  4. Replies: 6
    Last Post: 01-21-2003, 12:29 PM
  5. FS. VGA to TV (composite and s-VHS) converters.
    By Casper in forum Classified Archive
    Last Post: 08-13-2002, 05:33 PM
