NEW FLASH -- NEWS FLASH -- NEWS FLASH -- NEWS FLASH
I was able to shake the NiteMax tree this morning and knock loose several boxes full of goodies! I haven't looked closely, so I'll need to follow up with better information late this evening. The preliminary results are...
Procrastination is good -- patience is your friend...
Since I only just started assembling the NiteMax
cameras last night, a special opportunity has presented itself. EVERYONE WILL BE GETTING UPGRADED TO A COLOR CCD! Yup, you heard it right...
All 20 will include a color CCD. (Unless you tell me you don't want it!)
AC Power Adapters O-plenty
These are the good strong ones.
Battery Chargers
For the few who will use betteries.
Automobile Cigarette Lighter Adapter / Battery Simulator
I think there's some more of these. (Maybe)
CCD Boards with CS-Mount Adapter attached
This is the CCD board that takes 12v DC in and spits out a nice
video signal from the original NiteMax.
CCD Boards with 2x Digital Zoom.
Also accepts 12v DC and spits out a video signal.
Color CCD Boards with 2x Digital Zoom.
Accepts 12v DC and spits out COLOR video.
What's not here?...
The limiting factor that continues to be a problem is the lack of power supply boards. For this reason alone, there will be no more completely assembled NiteMax cameras.
I know a bit about the Power Supply Board and you can make everything work by using a substitute. If you can provide a regulated source of 12-Volts DC (like from a computer Power Supply) you have everything you need to operate the CCD and LCD. An adjustable supply is needed to have adjustable IR, but running the IR full-blast all the time might not be so bad!
With a little creativity, you can have all of the NiteMax functionality!
