Page 26 of 45 FirstFirst ... 161718192021222324252627282930313233343536 ... LastLast
Results 251 to 260 of 443
Thread: NiteMaxx digital night vision camera
  1. #251
    Constant Bitrate NiteMax Mark's Avatar
    Feb 2006
    I have researched this by studying the documents we have. I think there's a simple cure!
    Here's where Vertical Sync needs to go. I understand the circuit but I don't know what polarity you've got or what polarity the LCD Controller expects.
    I'd like you to try touching your VSYNC signal to this point on the resistor where I've shown. This is where VSYNC needs to ultimately reach!
    Quote Originally Posted by Fusion-One
    I was using the ole' PSONE timings.. but I just realized the two pins I Was trying to cram H/V sync into are actually outputs.
    So, I connected the H sync pin from the VGA connection to the composite sync input...
    The result is an image which is PERFECTLY stabilized horizontally.. it looks terrific... the only problem is, it slowly scrolls vertically =\
    This is the screen running at 640x480@60hz (no special timings).. now if I can just figure out how to get it to stop slowly rolling. :P
  2. #252
    Maximum Bitrate Fusion-One's Avatar
    Dec 2002
    Montreal, Quebec
    I gave that connection a try, but it doesn't solve the problem, unfortunately.. IT is definitely in the right area, though. When I intitally connect it, it causes a vertical shift in the image to a random position on the screen, and then continutes to roll.
    An error I made earlier, when I thought I was outputing 60hz vertical to the screen, powerstrip was still controling the refresh rates (windows rates were disabled) so while I thought it was eating up 60hz, it was actually taking in a touch under 30.
    Still scrolling. :P
    (Notice how readable that text is?? 640x480 on a 2.5" screen, and its actually readable! (The insanity!)
  3. #253
    Feb 2006
    Quote Originally Posted by kornkow
    I just got my lenses in the mail from (GESS) ebay yesterday! The camera is amazing! I got a 2.5mm F1.4, 2.8mm F1.4 (this one though I will have to adjust by backing out the two black screws in order to get it focused), and a 4mm F1.2 lens. the 2.5 and 4 looked great immediately. Yeah, ebay shipping does suck for something like this thats why I bought three lenses. I'm not sure which one I like best though. Wouldn't these be better than F1.6 (the ones youre trying to get) Mark?
    Yes, f/1.4 should be better than f/1.6. I found that the f/1.6 lenses worked better than the number predicted.
    Would you mind posting a picture of these lenses? I'd like to see how big the actual lens on the front is and how tall the whole lens body is. (I don't trust the pictures in the auction listings because I've noticed that some of them are wrong!)
    For a given focal-length (like 2.5mm) the lens with the larger glass area should have a better f-number. I'm wondering if yours actually have bigger glass glass than the ones I've seen.
  4. #254
    Oct 2003
    NiteMaxx Accessories Master List
    Lens
    dtran01
    at_b (2-3)
    turner brown
    bash1979
    Battery
    dmurray14
    Charger
    dmurray14
  5. #255
    Feb 2006
    Here's my vote for a decent lens (f/1.4) that most can afford (~$10.00) and it is adjustable to accomodate different needs. (3.5mm - 8mm)
    eBay Auction Link
  6. #256
    Jan 2004
    that looks nice, how many of us do we need to be in the list to start the group buy?
    also, since that seller has a big selection of lens, could we also get this model+a different one from there(i for one am interested in one of the lenses to have the fov bigger than 95 so i can use it in the back of the car)...just an idea
    thanks mark for doing this for us
  7. #257
    Newbie kornkow's Avatar
    Jan 2006
    Maryland
    Yes, no problem, I will try to post pictures of the three lenses when I get home tonight.
  8. #258
    Dec 2005
    Hi Mark,
    I got a 4mm f/1.6 lens and the picture is very very blury. You can hardly recognize any object. Any suggestions ? there is no display on lcd for night vision mode. Of course the lcd is working and I tried increading the gain for IR as well as contrast for LCD.
    Here is the lens.
    Thx
    http://cgi.ebay.com/4MM-4-MM-CCTV-Ca...QQcmdZViewItem
  9. #259
    Jan 2006
    Maryland
    try reading what mark recommended on pg 16
    In the picture there's a silver post for locking the focus in one place. Adjacent to this post are two black phillips-head screws that are flush with the lens body. (One is barely visible.)
    It turns out that the two black screws could be backed out almost all the way and this would remove the stop. All I had to do was lift up the screws far enough to let the stop mechanism pass by and then re-tighten them once I had turned it past. The effect was that I re-calibrated the lens by adding one turn worth of adjustment at one end of the focus range at the expense of one turn at the other end of the range.
  10. #260
    Feb 2006
    Quote Originally Posted by 0-0-7
    Hi Mark,
    Here is the lens.
    Thx
    I agree with what korn kow said! I've used the 16mm version of this lens and they do work -- some needed the adjustment.
    It does worry me that you say the focus is so terrible bad because that wasn't the case for me. At the risk of asking stupid questions, let me list the things that might be going wrong...
    - The silver stud sticking out is for locking down the focus. You'll need to unscrew it and rotate the outer body of the lens to focus.
    - Sometimes the lens gets jammed when you screw it into the camera body because you're actually applying force to the focus adjustment. If you can't rotate the endmost part of the lens while the part next to the NiteMax stays stationery, then it is jammed. You'll need to remove the lens from the NiteMax and twist the two parts in the "unscrew" direction to get them loose again.
    - Even if you can't adjust the focus, you should be able to have objects in focus that are extremely close or extremely far. Can you see an object that's a few inches from the lens?
    - For testing, you can extend the focus adjustment range by unscrewing the whole lens from the NiteMax. In fact, you can hold the lens a few millimeters in front of the CCD and get it to focus if it is way off. What you can't do is get the lens CLOSER to the CCD once it is screwed all the way in.
    Remember: The lens WILL focus when the CCD is at exactly the correct distance from the lens. A standard lens is expected to be a standard distance away from the CCD and this is what the CS designation is for. Not all things are equal and this is why lenses have a range of adjustment for focus. By playing with the distance between the CCD and the lens, we're trying to see which direction things are off by and by how much. Once we understand where the lens needs to be, we can make adjustements accordingly.
    - There's no Night Vision Mode -- it's always in the same mode. If you can see, the camera can see! If you can't see anything with your eyes (it's dark) the camera can't either. The camera can see IR. If you can't see and the camera can't see, turn on the IR -- you still won't see but the camera will.
  1. BMW E30 install with night vision
    By tekta in forum Show off your project
    Last Post: 07-01-2006, 03:41 PM
  2. Digital Still Camera as video feed (i.e. for reverse camera, etc)
    By meatwad in forum General Hardware Discussion
    Last Post: 01-26-2005, 06:50 PM
  3. low light night vision camera USB
    By Tred in forum General Hardware Discussion
    Last Post: 01-05-2005, 04:27 PM
  4. Is non-IR rearview camera visible at night with reverse lights on?
    By hd54321 in forum General Hardware Discussion
    Last Post: 07-23-2004, 04:21 PM
  5. Cheap camera with night vision
    By mxxxxxm in forum General Hardware Discussion
    Last Post: 06-04-2003, 12:55 AM
