Page 28 of 45 FirstFirst ... 181920212223242526272829303132333435363738 ... LastLast
Results 271 to 280 of 443
Thread: NiteMaxx digital night vision camera
  1. #271
    Constant Bitrate NiteMax Mark's Avatar
    Feb 2006
    Thank you!
  2. #272
    Low Bitrate PCModifiers's Avatar
    Dec 2005
    PMed you
    No one ever said this stuff was easy...The Mobile Desktop
    Progress[**********]
    Dolby Digital Real-time Encoding*Desktop Computer*Athlon XP Mobile*ASUS A7N8X Deluxe*Kingston Hyper X*5.25" CDRW and DVD drives*Lilliput 8" LCD*Mag 14" LCD
  3. #273
    Constant Bitrate spaceskater's Avatar
    Feb 2005
    Boston,MA
    So what lens are u guys using? I have been trying to decide what ls to use for the front side of the car but I still don't know... I got a bunch of them for cheep to test them but did not pay any attention that they all were F2.0 . When I decide on the lens I'll get a better one.
    I am leaning toward a 6 or 8mm lens. Less than that and I can't see far enough (killing the point of night vision camera). More than that and looking through it feels very weird since everything is zoomed and u miss all nearby details and looking through the camera wile turning is VERY uncomfortable.
    Will never be DONE! There is always something to add
    VIA EPIA SP13000,1GB DDR,80Gb 2.5” SATA HDD,8" Xenarc LCD with t/s,Linksys Bluetooth,Logitech wireless trackball,OBDII,RearView wide angle cam,XM radio,2 Wifi external antennas, Frodo,Navivoice
  4. #274
    Dec 2005
    Naples, Florida
    Quote Originally Posted by NiteMax Mark
    That sucks!
    Did you try the suggestion where you back out the stop screws on the lens and let it travel farther? This works until the lens bottoms itself out internally.
    Yes, that's what I did. The lens bottoms out - I'll try your other suggestions when I can get a chance to crack it open. Thanks for all your help!
    Quote Originally Posted by 0-0-7
    what is your other lens ? (I mean spec ?)
    I'm sorry, I can't remember right now. I'll look at it tonight when I'm home.
  5. #275
    Oct 2005
    I'm in for lenses.
    I'll take the battery pack if it's the real one not the car adapter pack.
  6. #276
    FLAC alti's Avatar
    NY
    I started my nightvision project in my car here
    Mark, I would like to get one of the nitemax ultras (the ones with out the power board, but the screen controller and color CCD) that you have, I also would like to get 6 of the IR LEDs that you have.
    My Install
    Software:
    CFiG v1
    iGuidance Plugin for CF
    CarShell
    Working shell for a CarPC
    StopWatch
    StopWatch plugin remade for centrafuse RC1
  7. #277
    Dec 2005
    while modifying the lcd, I removed all the wires but pin 5,9,11 from jp1.
    now my picture is upside down and not clear.
    Can someone post a picture of jp1 with all the wires attached as it comes from Mark so that I can put back the necessary wires back ?
    thx
  8. #278
    Feb 2006
    thx
    See Page 9
    Quote Originally Posted by Page 9
    - Apply 12v DC on JP1 Pin 11
    - Attach Ground to JP1 Pin 9
    - On the pads near JP1, connect a 5k Ohm potentiometer between the "5v" pad and the "Gnd" Pad. Connect the center (wiper) pin of the potentiometer to the "Brt" pad.
    - Feed the video signal in on JP1 Pin 5
    Here's the LCD Controller Board...
    Pin Name... I/O Pin Description...................... Remark
    1.. /Hsync. .O. Horizontal Sync...................... Output for specific Application.
    2.. /Vsync. .O. Vertical Sync........................ Output for specific Application.
    3.. NPC.... I/O NTSC/PAL mode selection.............. Note 1
    4.. SW..... .I. Composite/Analog RGB Signal Selection Note 2
    5.. CVS.... .I. Composite Video Signal Input.........
    6.. Bin.... .I. Separated Blue Video Signal Input....
    7.. Rin.... .I. Separated Red Video Signal Input.....
    8.. Gin.... .I. Separated Green Video Signal Input...
    9.. GND.... .-. Ground...............................
    10. GNDS... .-. Ground...............................
    11. Vin.... .I. 12 Voltage DC Input..................
    12. GNDS... .-. Ground...............................
    13. COL.... .I. Color terminal adjustment............
    14. LR..... .I. Left/Right scan selection............ Note 3
    15. UD..... .I. Up/Down scan selection............... Note 4
    Note 1: Default is auto detect for NTSC or PAL system.(Controlled by internal UPS015) High for NTSC mode and Low for PAL mode.
    Note 2: Default is Composite Signal (Low); High is for seperate Analog RGB signals.
    Note 3: Default is reversed scanning (High) and Low is for normal scanning (L —›R).
    Note 4: Default is reversed scanning (High) and Low is for normal scanning (U —›D).
  9. #279
    Dec 2005
    hey mark,
    so I need to make pin 14 & 15 high ? how do I do that ?
    also, what is the diff betn gnd (pin 9) and gnds (pin 10,12) ? are they tied toghether on the pcb ?
  10. #280
    Feb 2006
    hey mark,
    The original NiteMax configuration had 12, 14 and 15 tied together which would pull these pins LOW for normal operation. It looks like these pins have a pull-up resistor that makes them go high when no wire is attached.
    The documentation shows the GND and GNDS names. I believe these are the same but I can't see the traces on the PCB well enough to say for sure. I think it's a safe bet to assume that these are all ground.
  1. BMW E30 install with night vision
    By tekta in forum Show off your project
    Last Post: 07-01-2006, 03:41 PM
  2. Digital Still Camera as video feed (i.e. for reverse camera, etc)
    By meatwad in forum General Hardware Discussion
    Last Post: 01-26-2005, 06:50 PM
  3. low light night vision camera USB
    By Tred in forum General Hardware Discussion
    Last Post: 01-05-2005, 04:27 PM
  4. Is non-IR rearview camera visible at night with reverse lights on?
    By hd54321 in forum General Hardware Discussion
    Last Post: 07-23-2004, 04:21 PM
  5. Cheap camera with night vision
    By mxxxxxm in forum General Hardware Discussion
    Last Post: 06-04-2003, 12:55 AM
