Page 8 of 45 FirstFirst 123456789101112131415161718 ... LastLast
Results 71 to 80 of 443
Thread: NiteMaxx digital night vision camera
  1. #71
    Super Moderator xBrady's Avatar
    USA
    Although I won't know for sure until later today or tomorrow put me down for one and if it is legal, 2 of them. Thanks
    Installed.
    -GPSSecure- - GPS Tracking
  2. #72
    FLAC ukchris's Avatar
    Nov 2003
    Massachusetts
    Quote Originally Posted by KE5AFU
    Put me down for one of the cameras, a few LCD's and some of the arrays please.
    And yes you can power it with a Radioshack 9volt 800 Ma (273-1770) power supply and a "B" Adaptaplug (273-1705) tip.
    Thanks, much appreciated.
  3. #73
    Nov 2003
    Massachusetts
    Okay got the 800ma selectable voltage brick with tip B. It's putting out 9.3V when set to 9 but when connected to either camera the LCS looks partially lit but shows no picture and after 20-30 seconds starts to "blink". Both cameras do the same thing so I doubt its a camera issue, do you think it's the power supply?
  4. #74
    Newbie KE5AFU's Avatar
    Feb 2006
    OKC
    Might be, you might have to go up to the 1500 mA that we sell. I tried the 800mA in my store on the NiteMaxx and it worked great, in fact I'm looking at it right now. Take your camera by and try another one, if it doesn't work then the 1500mA will. There is about a 5 buck difference between the two.
    2001 Pontiac Trans Am Firebird WS6
  5. #75
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    ok, you guys gotta see this.
    sorry if its a repost
    turn your CVS one time use camcorder into a nightvision headset
    http://www.rpi.edu/%7Ebradfe/NVG2.html
    found that on hackaday
    PC Components:
    My work log
  6. #76
    Constant Bitrate NiteMax Mark's Avatar
    Feb 2006
    Quote Originally Posted by ukchris
    Crank it up to 12v and try again.
    I know how the NiteMax Power Supply works. It can handle up to 13v without hurting it.
    It draws constant power from the adapter so drawing 800mA at 9v means it will use more like 600mA at 12 volts. You may find that this is the difference you need!
  7. #77
    Maximum Bitrate Fusion-One's Avatar
    Dec 2002
    Montreal, Quebec
    If it accepts 12v, then I suggest just powering it off the PSU rails. :P
  8. #78
    Banned rev2's Avatar
    Dec 2005
    Does the NiteMax have reverse voltage protection? Not that I've done that yet.
  9. #79
    Nov 2003
    Massachusetts
    I just changed the wart for a 12v 1500ma one and it works great now.
  10. #80
    Feb 2006
    Quote Originally Posted by spaceskater
    Reposted.
    Well I put a list together so we can keep track. If I forget somebody just say so. The order is as I read the posts in this thread or the PMs sent to me.
    NOTE: About 20 NiteMax Cameras will be available
    1. Tostitos
    2. Genesisfactor (I think you have a few already)
    3. Spaceskater
    4. 0-0-7
    5. dmurray14
    6. thanatos106
    7. ROMbler
    8. greenman100
    9. tuner brown
    10. BLK MAJK
    11. Fusion-one
    12. McFreak
    13. amthar
    14. lostreception (probably send his to Genesisfactor since the live near by)
    15. jcaesar625
    16. pyro4fire
    17. quantum
    18. KE5AFU
    19. xBrady
    20. Peoples
    Well, the list is officially full!
    I have collected together parts for 20 cameras -- all in black. I am waiting on boxes from USPS for shipping. I am planning on using Priority Mail because it is faster and includes the box -- otherwise I'd need to buy them at an Office Supply store somewhere. I can also print postage at home and drop them at the Post Office without waiting in line. I'm guessing it will be next weekend before it all comes together.
    The cost will be $20 for the NiteMax plus the actual cost of Priority mail. You can expect something in the $4 to $8 range depending on how much additional stuff goes into the box. I have the following additional items that can be included at the same time...
    - CS-Mount to CCD adapter ring. (The one epoxied into the NiteMax housing) No additional charge.
    - CS-Mount to C-Mount adapter/spacer. Adapts C-Mount lenses to fit the NiteMax. No additional charge.
    - LCD with LCD Controller. Available in grey with silver or black available while supplies last. Cost is 2 for $25 plus $10 each for each additional.
    - 15-LED IR Array. 3 for $1.
    - Various NiteMax non-electronic parts. Need an extra housing to hack apart or modify? Let me know what you need and I'll include whatever I can for no additional charge.
  1. BMW E30 install with night vision
    By tekta in forum Show off your project
    Last Post: 07-01-2006, 03:41 PM
  2. Digital Still Camera as video feed (i.e. for reverse camera, etc)
    By meatwad in forum General Hardware Discussion
    Last Post: 01-26-2005, 06:50 PM
  3. low light night vision camera USB
    By Tred in forum General Hardware Discussion
    Last Post: 01-05-2005, 04:27 PM
  4. Is non-IR rearview camera visible at night with reverse lights on?
    By hd54321 in forum General Hardware Discussion
    Last Post: 07-23-2004, 04:21 PM
  5. Cheap camera with night vision
    By mxxxxxm in forum General Hardware Discussion
    Last Post: 06-04-2003, 12:55 AM
