Results 1 to 3 of 3
Thread: FS: Peripheral Electronics SVEN4 in the UK
    Jul 2005
    Wales, UK
    FS: Peripheral Electronics SVEN4 in the UK - London
    FOR SALE: Peripheral Electronics SVEN4 in the UK!
    eBay username: lloydcody
    Accept PayPal, etc.
    I recently bought a SVEN4 Line Output Converter (LOC) from the US but now I realise I do not need it. It is brand new in its box will all instructions.
    You cannot get the SVEN4 in the UK from anywhere so I had it especially shipped here by someone.
    The item is sold at $32.95 on plus $5.95 shipping plus $8.80 shipping to the UK - TOTAL: $47.70 = £27.50
    From the site :
    Peripheral’s Vendetta Series of interfaces are a must for today’s installations. More vehicles than ever are using a differential signal for their premium audio systems (Ford/JBL, Delco/Bose, Nissan/Bose, etc). These differential systems require unique interfaces to install aftermarket headunits or amplifiers with the OEM system. Peripheral’s complete line of Vendettas is the solution for factory to aftermarket audio system integration. All Vendetta products feature independent level adjustments, EIA standard wire colors, and compact housings.
    SVEN 4
    Four channel Premium Sound Interfacing Device.
    RCA level or speaker level input or output.
    The SVEN4 is perfectly suited for replacing the factory amplified system and retaining the OEM radio or for Premium OEM headunit replacement.
    Can also be used as a standard line output converter.
    NOTE: 60 watts maximum input per channel.
    Peripheral’s new Super VEN (SVEN) replaces the legendary Vendetta series of output converters, and has been created to interface the myriad of aftermarket A/V equipment with today’s sophisticated vehicle sound systems. This “super” adapter is great for adding an amplified subwoofer or separate amplifier to your factory JBL, Infinity, Mach, Premium, or Bose system. The SVEN has programmable input and output circuitry with selectable slide switches, which allows for either RCA or speaker level connections at both the input and output. DC coupling circuitry ensures noise-free integration and no load induced on the factory electronics. Four independent level controls and snap together housing make setting up the system even easier.
    Note: 60 watts maximum speaker level input per channel – 4 volts maximum RCA level input per channel.
    * 4-Channel RCA or Speaker Level Inputs & Outputs
    * Includes Interchangeable Speaker Harness & RCA Harness
    * DC Coupling Circuitry Eliminates Noise
    * Minimal Load on Factory Equipment
    * Independent Level Controls for Each Channel
    * Snap Together Housing Locks Wiring Harnesses In Place
    Typical Applications
    * Aftermarket Receiver to Factory Amplified System
    (such as Premium, Infinty/JBL, Mach, Bose systems)
    * Factory Receiver to Aftermarket Amplified Subwoofer
    * Factory Receiver to Aftermarket Amplifier
    * Speaker-To-Line-Level Converter
    Thank you for looking!
    Jul 2005
    Wales, UK
    This is still for sale and will be available on here ( forums) for another few weeks (from 17th Feb 2006) and then it will go on eBay.
    Jul 2005
    Wales, UK
    This is still for sale. Will be putting on eBay in a month or two. Let me kno...
  1. Replies: 2
    Last Post: 08-24-2005, 08:21 AM
  2. Replies: 0
    Last Post: 07-01-2005, 02:23 PM
  3. FS: (UK) 4" LCD composite monitor
    By terrastudios in forum Classified Archive
    Last Post: 04-14-2004, 06:24 AM
  4. FS: UK 12V Power system + Tank Circuit
    By Jamez_Warner in forum Classified Archive
    Last Post: 03-02-2004, 01:04 PM
  5. FS UK: 7" DSCUSTOMS / OPUS 150W PSU Plus More...
    By dave- in forum Classified Archive
    Last Post: 07-30-2003, 08:58 AM
