Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: FS FT Laptop Memory, Internal Laptop Wifi Card, HD, Bluetooth
    Jun 2005
    I have 2x256MB dimms for sale.
    Make me an offer! I need em sold!
    $25 Shipped
    They have about...1 hour of use on them I had other memory installed when I got the laptop.
    They are PC2-4200 DDR2 240 pin
    I also have an INTEL 2915 Internal MiniPCI for laptops
    25$ Shipped
    sold
    Bluetooth Speakerphone, Brand new never charged I won it from Motorola for a sales event. Exactly as pictured.
    -Rick
    http://www.mp3car.com/vbulletin/classified-archive/70918-fs-ft-laptop-memory-internal-laptop-wifi-card-hd-bluetooth.html#post759606
    FS FT Thread
    96 Eagle Talon TSI AWD
    Custom blue LED interior and Dash, Buddy club2, ViS Fenders, Phillips Ds2 Bulbs, Valeo-Fresnal ECE H7s, Mitsubishi Ballasts
    Constant Bitrate seanshine's Avatar
    May 2004
    Behind the Zion Curtain
    I'll take one stick of the memory,how about $20 shipped?
    edit- Damnit,sorry my laptop needs different mem.
    Any sufficiently advanced technology is indistinguishable from magic - Arthur C. Clarke
    Jun 2005
    Quote Originally Posted by seanshine
    sounds good, Paypal is firebretha@gmail.com please type your address in the notes section of the payment so I can make sure there are no typos, etc.
    http://www.mp3car.com/vbulletin/showthread.php?p=759606
    FS FT Thread
    Banned xdjxklusivex's Avatar
    Dec 2004
    Diamond Bar, CA (909,951)
    wat will u trade for the laptop hd and the bluetooth speakerfone??
    Jun 2005
    titanic of course!
    jk, things I need, 54g 108G internal pci card, money, thats all i can think of right now.
    FS FT Thread
    Maximum Bitrate CJ8501's Avatar
    Jul 2004
    Orland Park, IL
    Ill take the Hard drive....... PM sent
    Feb 2006
    Interested in INTEL 2915
    Hello,
    I have an Aopen Pandora that takes a mini PCI wireless card. Does you card come with the external antenna? If so how long is it?
    The card has a antenna connection, but does it have a small wire harness to wire the antenna connection to a bulkhead with a conector on the other end? Basicly, what I need is to connect the card to the board and have a connector on the case where all the connections go. From there I will add an external antenna.
    If it looks like it will work I'll take it.
    Best regards,
    Marc
    Jun 2005
    actually the card is "as is"
    the antenna was mounted within the laptop so it remained there. It uses tohose pop on connectors you see in the picture.
    other than those two pop on connections there was no other way to connect to the card.
    -Rick
    FS FT Thread
    Raw Wave BoyNextDoor's Avatar
    Aug 2004
    Walden, NY
    i take the Laptop HDD if the other guy falls thru. Damn me being slow...
    Low Bitrate JPMG's Avatar
    Jan 2006
    Mini-PCI WIFI Card hookup to external antenna ...
    I saw the note about the card and had the same situation ... and solved it.
    The mini-PCI wifi card should have two connectors, one MAIN and one AUX. Both use mini coax connectors.
    I fixed mine with two parts, one is a PIGTAIL conector. It has one end with a mini-coax and the other has a bulkhead connector for my antenna. Mount one end to the card and the bulkead on the case. Very easy to use an external antenna.
    The second part is a mini antenna that fits into a lapopt. That one goes on the AUX. The little one is then mounted inside the case.
    With the external connected I get excellent reception. When on the bench in the shop, the internal works fine.
    Ends up a simple, seamless solution.
    Enjoy!
    ... Mike ...
  1. FS: Hitachi 40GB Laptop HD
    By KKDZ28 in forum Classified Archive
    Last Post: 05-20-2004, 10:56 AM
  2. 2 external laptop hd enclosures FS USB 2.0
    By outragis in forum Classified Archive
    Last Post: 03-11-2004, 06:05 PM
  3. Replies: 3
    Last Post: 03-10-2004, 12:01 AM
  4. FS: 40gb laptop HD
    By lzrdkng14 in forum Classified Archive
    Last Post: 03-08-2004, 10:43 AM
  5. Replies: 10
    Last Post: 01-30-2004, 08:47 PM
