Results 1 to 10 of 14
Thread: xtant amp and shroud (for car pc)
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    Hey guys,
    i have a 603x xtant amp and empty shroud for sale. This setup will give you an ultra clean looking install where you'll have a matching car pc case and amp. this is the cleanest amp i've owned but i'm totally redoing my install and the amp has to go.
    looking for $400 b/o for the set
    Channels: 3
    Watts Per Channel: 4 Ohm 2 x 75 + 1 x 150, 2 Ohm 2 x 150 + 1 x 300, Bridged 4 Ohm 1 x 300 Watts
    Freq. Response: 5Hz to 50kHz +/- 1dB
    Distortion: <.04%
    Signal to Noise Ratio: >100dB
    Damping Factor: >200 @ 100Hz with 4 Ohm Load
    Input Sensitivity: 40dB
    Stereo Ch. Crossover: 12dB Octave
    Mono Ch. Crossover: 12dB Octave
    Line Outputs: Yes
    Noise Gate: Yes
    Passive Outputs: Yes
    Module Ports: 4 Accessory
    Power Supply: Regulated, PWM
    Operational Voltage: 11 to 15 Volts
    Fusing Requirements: 100 Amps
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Dec 2004
    Los Angeles Ca
    oh...this amp is stable at 2 ohms on the third channel! it's pushing my cdt components up front and a 12" image dynamics sub in the rear...sounds awesome!
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Low Bitrate schpanky's Avatar
    Jul 2005
    what are you replacing it with?
    1995 Ford Mustang Convertible
    DSATX | Shuttle XPC SN41G2Bv2 | 619GL-70NP | CF 1.6 (which is still unusable in the car!)
    Tainted Love Cris's Avatar
    Romania
    Is that only 1 amp in the pic?
    Dec 2004
    Los Angeles Ca
    i'm not gonna reveal what i'm replacing it with until the install is finished. The new amp is really nice, but a bit expensive.
    in the pic there is one amp and one amp 'shroud' where the car computer is installed under.
    M10k
    My Car Pc Install
    My Boat Pc worklog
    It ain't easy being a green moderator meddler's Avatar
    Aug 2002
    Steps out the front of Henson's workshop or Sydney
    man, I so wish I could buy this amp!!!!
    Dec 2004
    Los Angeles Ca
    you can! it's for sale :-)
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Aug 2002
    unfortunately I have a few bigger problems than buying a new amp at the moment.
    May 2005
    Toronto, ON
    This is an awesome amp. I have the same pre-mitek one. Seriously underrated.
    Aug 2005
    south GA
    xtant
    man... prices on the net are all over the place... from ebay to other sites.... how much do the covers run... did a quick search couldnt realy find a solid price..... great idea on the covers...
    96 cobra
    suspension: MM CC plates, H&R super sport, bilsteins, steeda:bump steer kit, X2's, moly SFC's, triax shifter. MGW handle, cobra knob. Audio:RUX-C701, PXA-H701, MRV-F545, MRD-M1005, SIR-SC-H1, DMHD1000, Polk/Momo MMC6500, MM2104
