Results 1 to 2 of 2
Thread: FS: Some things
    Jan 2006
    FS: Some things
    Selling my danger den RBX waterblock, has socket 478 fittings. Only used about a month, no mildew or any yucky stuff. Lapped the bottom for maximum heat disapation. Includes all the fittings and hardware for your setup. Lucite top.
    $45.00 Shipped
    Massive Cooling Radiator, designed to cool a house. This is used in HVAC to cool liquid for AC, brand new part from factory, over 5000 contact points. Copper tubing, aluminum fins. Will not rust at all. I was going to mount it to the side of my case but changed my mind for air cooling.
    3/8 ID copper tubing, aluminum fins, high flow design.
    The dimensions are as follows 18"x 12" x 2"
    $65.00 Shipped
    Via aqua 2600 Pump, maximum 8ft head, 720gph. This is one strong pump, it cooled my 3.4 prescott to 15c at full load with a dual 120 black ice pro 2 on a t line setup. Had 2 delta fans that pushed lotsa air.
    $40 Shipped
    Mini ITX System (shuttle, upgraded proc to 1ghz p3, 512 ram, onboard video and video out, firewire, network, usb, parallel and serial)
    $350 Shipped and insured
    VIA 800mhz CPU (Socket 370, pulled from the mini ITX system)
    $40 Shipped
    IDE Firewire Adaptor (comes with firewire cable)
    $15 Shipped
    Mobile Infared Transmitter (MIRT) kit. AKA a traffic preemption device.
    Comes with all the parts needed to assemble, I will also include my personal detailed instructions on how to solder it togheter.
    $50 in pieces $70 built.
    Elsewhere
    Quote Originally Posted by v3r71g0
    bump
    No, no bump. Read the rules before posting in the classified section. It specifically states not to bump your own thread.
    This is your warning.
    How about the Wiki?
  1. Funny things found in 109
    By Don 944 LA in forum FrodoPlayer
    Last Post: 10-20-2004, 12:13 AM
  2. FS: Buncha Things 2
    By TheNoodPoopler in forum Classified Archive
    Last Post: 08-12-2004, 11:29 AM
  3. FS: Morex DC-DC from Cubid Case $35
    By ELEmental59437 in forum Classified Archive
    Last Post: 02-09-2004, 01:11 AM
  4. Couple Things FS
    By Foobar in forum Classified Archive
    Last Post: 01-31-2002, 04:05 PM
  5. FS: Keypower KP-DX 250H, Dschimdt Auto-Off ATX, and MORE!
    By pinkysqueaks in forum Classified Archive
    Last Post: 10-10-2001, 03:36 AM
