Results 1 to 7 of 7
Thread: NIB M2-ATX DC-DC ATX auto car PC power supply mini ITX EPIA
    Jun 2006
    Lightbulb NIB M2-ATX DC-DC ATX auto car PC power supply mini ITX EPIA
    I bought this..
    then i ran into $$ problems..
    i had to go with a broken lcd laptop..
    so my powering requirments have changed...
    im selling this for exactly what i paid for it...
    no more no less...
    i prefer a paypal payment...
    but email me about any other payment methods...
    *New Release* M2-ATX intelligent Automotive / Car DC-DC ATX PC 160W Power Supply
    MSRP: $89.95 Your Price: $79.95
    Features
    * 160 watts output
    * Ideal car Power supply for operating P4, P4-M, Celeron, AMD systems
    * ATX, 6-24V wide input range
    * Intelligent shutdown controller
    * ON/OFF motherboard control
    * Survives vehicle engine cranks
    * Battery deep discharge prevention
    * Works with 12V / 24V car batteries
    * "Anti-Thump" amplifier remote control
    * 15A automotive fuse (mini-blade)
    * Works with all VIA mini-ITX motherboards
    * VIA, P4 and AMD CPU support
    * Standard 1 year manufacturer's warranty
    Package Includes (see image below)
    * ATX/HDD/Floppy cable harness (9 inches)
    * 3 faston connectors (12 inches)
    * 1 two-pin motherboard on-off switch wire (9 inches)
    * 4 jumpers for controlling power sequencing schemes
    * Installation Manual
    Dimensions
    6.5" (16.5cm) x 2" (4.5cm)
    Weight: (Including cables) 1 lb (0.45 kg)
    Description
    Intelligent Automotive / Car DC-DC ATX PC Power Supply
    The M2-ATX is an intelligent, high power, vehicle (car / boat / electric cart) 12V DC-DC ATX PC power supply designed for CarPC and battery powered applications. Designed to provide power and to control the ON/OFF switch of a motherboard (CarPC) based on ignition status, the M2-ATX is a wide input (6 to 24V) vehicle/car/ battery operated ATX power supply capable of surviving tough car engine cranks (down to 6V) as well as transient over-voltage situations. Just connect it to and power up your PC!
    The M2-ATX comes equipped with ATX/HDD/Floppy cable harness , jumpers, faston connectors and 2 pin cables for motherboard ON/OFF switch. Just connect it to your 12V or 24V car / boat / RV battery and power up your PC.
    The M2-ATX has 8 user selectable microcontroller driven timing modes, allowing you to choose up to 8 ignition/shutdown CarPC timing schemes via a built-in shutdown controller. By removing all user-selectable jumpers, the M2-ATX becomes a traditional PC PSU with no ignition control (shudown controller bypassed) and it can be used in non-vehicle computer applications.
    Even if your computer is completely OFF, a PC will still consume a few hundered milliwatts, needed to monitor PC ON/OFF status. When the computer (CarPC) is in the suspend/sleep mode, it will consume even more power, because the RAM needs to be powered at all times. The power consumption in the suspend mode is few watts. No matter how big your car battery is, it will eventually drain your car battery in a matter of days.
    While in deep sleep mode, the M2-ATX constantly monitors your car battery voltage levels, preventing deep discharge situations by automatically shutting down (using a built-in shutdown controller) until battery levels reach safe levels again. No more dead car batteries, no more computer resets during engine cranks, along with multiple timing schemes, small formfactor and very competitive price makes the M2-ATX the premier solution for dc-dc ATX vehicle/CarPC power supply solutions.
    NOTE: The M2-ATX provides up to 8A on the 12V rail, making it ideal for operating most P4, P4-M, Celeron, ADM systems. Low power Geode and VIA processors (C3, C7) will work as well, leaving ample power for 12V or 5V peripherials (multiple 3.5" hard drives, CDROM, etc).
    Compatibility
    Motherboards
    The M2-ATX works with the following motherboards:
    * All VIA mini-ITX boards
    * Pentiums, P4
    * AMDs
    Please check your motherboards specifications and make sure that the CPU is not getting V(core) from the 12V rail (should be on the 5V rail).
    Not recommended for motherboards with Pentium 4s and motherboards that have 4 pin 12V ATX connectors, which is an indication that the motherboard is using 12V for V(core).
    Newbie DjCalvin's Avatar
    Jun 2006
    MA
    Check your PM
    Aug 2003
    did you get an M1 instead?
    Ichiban, if you need one, I have one for sale.
    Jun 2006
    MA
    Payment has been sent.
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    I knew it would sell...
    Tidder
    Try RevFE
    Jun 2006
    Quote Originally Posted by djcalvin
    i'll email you tracking number and further info...
    Quote Originally Posted by Tidder
    yea i appriciate the suggestion...
    dont know why i didnt think of it myself
    Jun 2006
    MA
    Recieved last week.
    Thank you!
  1. can I power a car stereo with an ATX PSU?
    By Fourgig in forum General Hardware Discussion
    Last Post: 09-08-2009, 07:40 AM
  2. PC Power Supply and Car Amp
    By GezusK in forum Car Audio
    Last Post: 05-10-2006, 01:31 AM
  3. Replies: 7
    Last Post: 06-15-2004, 10:29 PM
  4. AC or DC power supply w/ tablet pc?
    By gutterslide in forum Power Supplies
    Last Post: 04-07-2004, 04:12 AM
  5. DC-DC car power supply for ITX case
    By mrandery in forum Power Supplies
    Last Post: 08-30-2002, 09:30 AM
