Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: wanted: specific shape USB hub, pic inside
  1. #11
    Mar 2006
    Colorado, but Canadian!
    Well, good to hear that you got it to work. Post up some pics when you get around it.
    1.9in x 2.9in -- 47mm x 73mm
  2. #12
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    It late but may help other if they run into the same need.
    http://shop4.outpost.com/product/415...H:MAIN_RSLT_PG
    I have one of those. 2 port on 1 side + mini usb input and 2 port on the other size with aluminum case. Just a little bigger than a CF card and about 1/8" thicker.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  3. #13
    Jul 2006
    this may be a stupid question, but does a hub like this have the ability to turn one usb port from the computer into 4 ports for 4 different devices? i would imagine it would be easier just having one long cable from the laptop in the trunk to the hub in the front, and then i could plug in all my devices using shorter cables into the hub. is there any downside to this?
  4. #14
    Constant Bitrate damarble's Avatar
    Jan 2006
    Spokane
    One of the most suckass pics of all time, but it gets the point across. The assembly is epoxied behind a panel that's finished nicely.
    {Xenarc 700TSV} {Celeron M 1.3 ghz} {ASUS mATX mobo w/CT479} {MX440 128mb AGP} {1x512mb RAM} {3.5" Seagate 40gb (rated at 350 G's)} {M1-ATX}
    MY INSTALLATION LOG
  1. Powered Hub, Lots of USB Devices! Will this work?
    By adamharrisuk in forum General Hardware Discussion
    Last Post: 05-15-2006, 12:00 AM
  2. WTB: M2-atx, USB 2.0 hub, USB 2.0 pci card, etc
    By CavityCr33p in forum Classified Archive
    Last Post: 01-30-2006, 06:57 PM
  3. USB Audigy 2 NX, D-Link USB Hub, and 15 W POL
    By Caelric in forum Power Supplies
    Last Post: 01-17-2006, 01:02 PM
  4. USB HUB Powering
    By Cheekz185 in forum General Hardware Discussion
    Last Post: 08-18-2005, 08:25 PM
  5. USB soundcard through hub?
    By wizardPC in forum General Hardware Discussion
    Last Post: 12-01-2004, 02:03 PM
