Results 1 to 10 of 14
Thread: wanted: specific shape USB hub, pic inside
    Constant Bitrate damarble's Avatar
    Jan 2006
    Spokane
    Hey guys I'm on the lookout for a USB hub and was hoping somebody here had one or has seen one in a store. It needs to have 2 ports on one side (or end) and at least 1 port on any of the other sides. I've found plenty that have 2 or 4 ports on one side, none on the others, or ones that have 1 port on each side. Here's a couple drawings to show what I'm looking for. (Yes, the one is geometricly incorrect, but I needed to show both sides.) Thanks!
    {Xenarc 700TSV} {Celeron M 1.3 ghz} {ASUS mATX mobo w/CT479} {MX440 128mb AGP} {1x512mb RAM} {3.5" Seagate 40gb (rated at 350 G's)} {M1-ATX}
    MY INSTALLATION LOG
    Mar 2006
    Colorado, but Canadian!
    Like this:
    And it is powered too:
    Found it at newegg: http://www.newegg.com/Product/Produc...82E16817126001 for $8.99
    1.9in x 2.9in -- 47mm x 73mm
    Jan 2006
    Spokane
    Almost. But the ports have to be stacked like in my pic.
    I think I've got something figured out with a hub I have, that has 1 port on every side. But if anybody finds anything please post up.
    MY INSTALLATION LOG
    Mar 2006
    Quote Originally Posted by damarble
    turn it sideways?
    Newbie OmegaAvenger's Avatar
    Apr 2006
    Austin Texas
    Why so specific?
    Raw Wave kickercivic1's Avatar
    May 2003
    Florida
    how many at a time you going to use??
    Jan 2006
    Spokane
    Quote Originally Posted by OmegaAvenger
    Why so specific?
    I need to put it in a very small area that the ports must be oriented just right.
    Quote Originally Posted by kickercivic1
    Ports? At least 2 at all times, sometimes up to 4.
    MY INSTALLATION LOG
    Apr 2006
    Austin Texas
    I have never seen a usb hub in that shape (or close to it for that matter) and i work at a computer store and we have a variety of hubs.
    Mar 2006
    I think your best bet is to use 2 of the hubs with ports on all four sides. Then stack them one on top of eachother.
    Or if you know how to solder (and u should!), then use the one with ports on all four sides, and move the left and right port to above the front and back, creating the same as in the picture for like 5 bucks and 30 minutes of work (to make it look good that is!).
    Jan 2006
    Spokane
    Quote Originally Posted by 2k1Toaster
    THat's almost what I ended up doing right before I saw your post. I took the hub's guts out of the cae and made a new chassis out of 1/8" ABS, screwed the board to it, then epoxied the end of a short USB extension cord to the other side. Tada, just what I needed. I might post a pic if I get around to it.
    So not needed anymore! Thanks to you guys that helped!
    MY INSTALLATION LOG
  1. Powered Hub, Lots of USB Devices! Will this work?
    By adamharrisuk in forum General Hardware Discussion
    Last Post: 05-15-2006, 12:00 AM
  2. WTB: M2-atx, USB 2.0 hub, USB 2.0 pci card, etc
    By CavityCr33p in forum Classified Archive
    Last Post: 01-30-2006, 06:57 PM
  3. USB Audigy 2 NX, D-Link USB Hub, and 15 W POL
    By Caelric in forum Power Supplies
    Last Post: 01-17-2006, 01:02 PM
  4. USB HUB Powering
    By Cheekz185 in forum General Hardware Discussion
    Last Post: 08-18-2005, 08:25 PM
  5. USB soundcard through hub?
    By wizardPC in forum General Hardware Discussion
    Last Post: 12-01-2004, 02:03 PM
