Results 1 to 10 of 16
Thread: FS: Rockford Fosgate Subs/AMP - ALPINE Speakers
    Jul 2006
    Las Vegas
    FS: Rockford Fosgate Subs/AMP - ALPINE HU/Speakers
    FS
    1 Alpine CDA-9847 HeadUnit .. SOLD to lime
    1 RF 900w monoblock amp
    2 RF Stage 2 Punch 10" DVC Subwoofers
    1 Alpine Type-R 5x7 Component Pair
    1 Alpine Type-R 6x9 Pair
    Each of the four listed items are 70$ shipped each in the US.. extra for other countries... or 300$ shipped for the lot now deck is gone
    The subs also are currently mounted in a ported Q-Logic box which is for sale too if desired for 20$+ whatever shipping is.
    Subs and speakers purchased end of March 06 at Best Buy. Have extended warranty, need to read if it is transferrable. Amp purchased at Best Buy few years ago. Older model, actual picture not uploaded, but here is link to same amp. http://i24.ebayimg.com/05/i/07/a9/3a/6b_1.JPG
    PM/Email at setyte@gmail.com or AIM at maddmarshall2k
    This is basically a full system. Arguably it needs a 4 channel amp to make the Type-R speakers really shine. They sounded great to me without an amp, if you choose to pick up an amp they will be even better.
    subs a model p210d4 so punch stage 2 dual voice coil 4 ohm 250w rms 500w max
    subs / alpine speakers purchased march 31 for 119.99 each... used from then through mid june when i bought a new car which i have not put the system into. subs are 70$ shipped if you split them... 120 shipped for both... im negotiable on prices though I'm sure if you check ebay you'll find them to be on par
    AlphaDamp CLD Mat - Get more Sound Deadening with less Sound Deadener
    Constant Bitrate damarble's Avatar
    Jan 2006
    Spokane
    Ygpm
    {Xenarc 700TSV} {Celeron M 1.3 ghz} {ASUS mATX mobo w/CT479} {MX440 128mb AGP} {1x512mb RAM} {3.5" Seagate 40gb (rated at 350 G's)} {M1-ATX}
    MY INSTALLATION LOG
    Maximum Bitrate CJ8501's Avatar
    Jul 2004
    Orland Park, IL
    link for specs on amp?
    Jul 2006
    Las Vegas
    tryign to find them... its an older model... im having trouble finding an archive of RF amps
    ok i finally know the model ... it was very small... 301m... states 900w... looking for spec sheet now
    Jul 2006
    Las Vegas
    http://www.rockfordfosgate.com/scrip...ted=1083265782
    thats what i found... pdf... excerpt from page 10
    SPECIFICATIONS
    MODEL PUNCH 301M
    Maximum Power Rating
    All Channels 900 Watts
    Dynamic Power Rating - Measured at 14.4 Volts
    Mono into a 4Ω Load 150 Watts
    Mono into a 2Ω Load 300 Watts
    Signal-to-Noise Ratio >100dB A-weighted
    Crossover Slope 12dB/octave Butterworth
    Crossover Frequency variable from 50Hz to 250Hz
    Crossover Type variable AP/LP
    Dimensions: (with Endbell)
    Height 2.38" (6.05cm)
    Width 9.85" (25.02cm)
    Length 12.07" (28.12cm)
    Frequency Response 20Hz to 20kHz ±0.5dB
    Bandwidth 10Hz to 100kHz ±3dB
    Damping Factor @ 4Ω (at output connector ) >200
    Slew Rate 30 Volts/ms
    IM Distortion (IHF) <0.05%
    Source Unit Compatibility (+15dB gain overlap) 17V max. (low level in)
    Acceptable Signal Voltage Range Variable from 100mV to 6V (RCA Input)
    Variable from 0.5V to 11V (High Level Input)
    Protection NOMAD - Internal analog-computer output protection
    circuitry limits power in case of overload. Thermal
    switch shuts down the amplifier in case of overheating.
    Battery Fusing Rates (External to Amplifier) 30 amps
    Fuse Type ATC
    Equalization (Punch Bass) Switchable from 0dB to +6dB to +12dB
    Input Impedance 20k ohms
    Newbie lime's Avatar
    Jul 2006
    scarborough, Ontario
    payment sent for the head unit.
    thanks
    Jul 2004
    Orland Park, IL
    any pics of the amp? any scratches on it at all? interested in that and the 6x9s
    Jul 2006
    Las Vegas
    placed head unit in usps's hands a few hours ago... will post pictures of amp soon as camera charges up enough.. dont see a single scratch on it
    Jul 2006
    Las Vegas
    Its just dusty.. no scratches... if need be i could wipe it down prior to shipping.. i live in vegas... in a particularly dusty area.. amp is in full working condition... pumps out the jams like it were hott off the line.
    Newbie tjsharktank's Avatar
    Jul 2006
    Charleston
    I just sent you another email - I'll take the subs. See my email.
    Thanks.
    Sara - I'm a geek from the word go!
    2004 Nissan Titan
    2004 Mazda3- Plans: Mac Mini, LCD, etc.
    Previous Cars: 1999 Camaro- Alpine HU, Polk Comps, 2 Alpine 12" subs, custom encl
    DON'T BUY FROM SETITE - HE'S DIRTY!
  1. FS or trade: (2) Rockford Fosgate 15" DVC subs
    By PitchBlack98 in forum Classified Archive
    Last Post: 08-24-2006, 11:42 AM
  2. FS: Rockford Speakers / Amp / 50F cap
    By therussman2002 in forum Classified Archive
    Last Post: 06-08-2005, 09:09 PM
  3. FS like new Rockford Fosgate Punch Stage 2 10 inch sub w/box
    By carchrism5 in forum Classified Archive
    Last Post: 05-21-2005, 09:23 PM
  4. (fs). Rockford fosgate new/old series audio equip
    By faiz_23 in forum Classified Archive
    Last Post: 05-12-2005, 11:42 PM
  5. FS: Rockford Fosgate Punch 400S amp
    By SiGmA_X in forum Classified Archive
    Last Post: 01-13-2004, 02:29 PM
