----FS/FT Rules - Read These First!---- (Updated 21 Nov 06)
Please read and obey the rules:
* DO NOT "BUMP" YOUR THREAD. added by fiberoptic 6-11-05
Hello all,
I have 2 brand new LIND voltage regulators. one is rated for 11-16Vdc 8A max input to 12Vdc 3.0A regulated output.
The other is rated at 15VDC 5.5A output with fuse and comes with Panasonic toughbook cables and lighter adapter cable supplied.
Perfect for laptops or carputers where a solid regulated voltage is required, smaller equipment in the car or from a generator. LIND is known for there superior performance in voltage regulation. You can purchase cables for any item you want to run off this or make your own.
The first one has the following specs
Input Voltage 12 - 32 Vdc 24 28 24VDC 28VDC
Output Voltage 15.6 Vdc & 9 VDC
Output Current 4 amps & 3 amps (max)
Connector 2.5mm x 5.5mm & 2.1x5.5mm XM
Auto Input Cable 36 inches
Airline Input Cable n/a
Output Cable 36 inches each cable
Fuse 12 amps
Size 8.5 x 2.4 x 1.25 in
Weight 14 ounces
The second one has these specs
Input Voltage 20 - 32 Vdc 24 28 24VDC 28VDC
Output Current 5 amps (max)
Connector MP205 & 2.5 x 5.5mm
Auto Input Cable 72 inch S&T cable
Output Cable 72 inches (both cables)
Fuse 15 amps
Size 5.0 x 3.0 x 1.15 in
Weight 13 ounces
Please specify which one you want.
You can view the company and there parts at www.lindelectronics.com
$40.00 shipped each
I accept paypal of MO only
Adam
daddyforman@gmail.com
Jan Bennett
Roger .... thanks...
I am not trying to bump
