can you price out just eh monitor? thanks.
Hi,
I've had this monitor for about a month, it's in very good shape. I will take pictures later and post them for you guys.
I also have a carpc from lilliput, in Brand New condition. I pulled it out of the box and installed windows, to make sure everything works. It's a good unit.
both units are 1 din each, so if you have a 2din car, it would look good.
Asking price is 800$ USD for both, or I can sell them separately. (Free shipping within the US if you buy both at 800$)
If you have questions, please email me.
shl0791@gmail.com
Cant code cause I dont know how, but give me the paint bucket and my eraser and have at you!
Here are some pix!
Specs will be next.
I had a problem with the first unit DQT sent me, but they didn't fix it at all, instead, they sent me a new one with a bigger hardrive!This is why the unit is brand new in the box (tested, brand new wire harness etc.) Unit will come bundled with Windows XP pro. and a legal COA.
The display screen is in very good condition like I had stated, and has mounting holes I had to drill on the sides. Does not affect functions of the unit. Also, this is one of the later units, and has no problems whatsoever.
Specs:
• Lilliput BlaXtream TC-1000 one Din In-Dash Computer system with 1G CPU, 512Mb DDR Ram , 40GB Hard drive onboard Sound card, onboard Lan card and onboard Modem.
• CD/RW burner & DVD player built in
• Main Frame ( For In-dash installation )
• Full function Remote Controller
• 100v-240v Power AC adapter
• Five-Core automobile power connection cable
• Audio output wire (RCA out )
• VGA extension wire
• USB extension wire
• Computer Instruction menu
• DVD player User's menu
• Onboard application driver software CD
• Bluetooth Driver software CD
• Carrier fixing frame
• Panel plastic frame
• Lilliput Fully 1 Din In-Dash Car PC DVD Player System with CD/RW
• Working Voltage from 7v to 24v
• Working current from 2.2A to 4A
• VIA BlaXtream TC-1000 with 1 GHz CPU,266MHz Bus (DDR),VGA card ,Sound card ,LAN card on board .
• DVD Rom build in
• 512 MB DDR Ram
• 40 GB Hard Drive - 5400 RPM and 8 MB cache
• Bluetooth on board
• Dimensions : 195 x 177 x 54 mm
• Weight : 1.55kg
• Computer : This product can be operated as a Car PC or Home PC when adapted with a mini LCD monitor or Home PC monitor .
• DVD Player and CD/RW burner : This product can play various media Discs such as CD, Mp3 , VCD and DVD . This is an instant boot-up Media player, which means the users can play Disc Media without booting up the computer Operating system.
• Extension Functions: This computer is designed with the bluetooth communication function and four USB ports, through which , the user can extend this machine with cordless keyboard and mouse, wireless earphone , GPRS modem, GPS navigation antenna, DVB-T digital TV receiver etc.
• Bluetooth Communication: For the operation instruction of the bluetooth communication mode , please refer to the following two*.pdf files in the bluetooth installation CD.
• English blueSoleil Usermanual 1.4.pdf
• English IVT blueSoleil 1.4-GAQ.pdf
• Compact Design: with the dimensions of 195 x 177 x 54mm , it is easy to be installed and carried. High Performance Specification: CPU 1G , Memory up to 512mb , 40GB Hard Disc , DVD drive & CD/RW burner. Lower Power consumption: maximum power consumption of this machine is 48W. Rated power consumption is lower than 30W . Energy saving and efficient heat emission performances make is applicable to the car environment. Professional make is applicable to the car environment. Professional design: it is specially designed for the application under vehicle environment with good mechanical structure and electrical design, such requirements as anti-vibration, heat emission, anti-disturbance, and power separation ca be satisfied; and the following severe operation conditions under vehicle environment can be improved, including vehicle jounce, high and low temperatures , surge current, and electromagnetic disturbance. Intelligent Power Control-this equipment has special Intelligent Power Control system .
• Wide voltage range input: this car PC can normally work ranged from 7V to 24V,overcoming the disadvantage of non-stability of vehicle battery voltage, especially the insufficient instantaneous vehicle ignition voltage.
• Automatic Delay shutdown: after "ACC" ( automobile electric lock ) switches off the power , the computer can automatically normally shut down and has 20 second delay to switch off the whole computer's power supply to ensure the normal PC shutdown.
How much for just the monitor? I'll even give you mine.
CarDomain for my Silverado. Updated 2-20-07!!!
DropJawMag pic #1 of my truck at ShowFest '06.
DropJawMag pic #2 of my truck at ShowFest '06.
DropJawMag pic of my truck at Scrapin The Coast '06.
how much for just the pc part
500$ for the pc part 300$ for the screen (Mp3car.com) sells it for 469$
The whole thing cost me about 1100-1200 total. Good setup, I'm just not very good at making things work out. I'm going to try to get a Pioneer d2 or z1 in my car. A little easier for me.
What model is the monitor? AM/FM/TV?
