Results 1 to 6 of 6
Thread: Possible FS: 60GB HD with StreetDeck
    Mar 2006
    NY
    I might be looking to switch from StreetDeck so if I do I'd be selling my hard drive with StreetDeck installed on it. Probably looking for around $180 - just checking if there's any interest.
    BTW - this is a Fujitsobo 2.5" hard drive. Barely used.
    Mar 2006
    NY
    bump
    Any interest at all? Willing to work on price.
    Oct 2004
    NY
    doesn't streetdeck do a hardware check? have you tried this in other systems.... even if sd doesn't give issue, windows probably will... unless the system it goes into is very similar hardware wise to the system it came out from.... what was it running on? is it a licenced copy of windows? home or pro?...
    I think chances of finding someone who can just pop this into there system & be good to go is pretty slim....
    Mar 2006
    NY
    streetdeck uses the hard drive as a check so you just need the harddrive. It will have licensed Windows XP Home on it but you can wipe it and put whatever you'd like. As long as you use the same hard drive you should be fine.
    Oct 2004
    NY
    ok, that should clear it up for some who might consider purchasing this from you, now you may see a bit more interest here
    good luck with it
    Mar 2006
    NY
    Sold
  1. Fs: HD TV 34'
    By amdpro in forum Classified Archive
    Last Post: 01-31-2006, 01:37 PM
  2. FS: Custom AMD computer (ADM 1400+, 60GB HD, 256mb ram) $199
    By viper24 in forum Classified Archive
    Last Post: 12-15-2005, 12:46 PM
  3. FS carputer M10000, 60GB HD, 256mb
    By rdesai in forum Classified Archive
    Last Post: 06-13-2005, 06:02 PM
  4. FS: (2) 60GB 7200RPM IBM Deskstar 3.5" IDE HDD's
    By hd54321 in forum Classified Archive
    Last Post: 05-24-2005, 02:43 PM
  5. FS: Opus 150W, 60GB HD, Sereniti case
    By aoLhaTer in forum Classified Archive
    Last Post: 01-30-2005, 04:38 AM
