forgot to mention.... offers accepted!
Up for sale is a Freetech Pentium 3 Mini itx motherboard with a 1.2ghz CPU and low profile heatsink and fan and 256mb ram. Used it for a few months. Alot faster than most epia boards. Here are some specs.
Asking 150 shipped
Mainboard Specifications and Features
Hardware
IntelŪ FC-PGA, FC-PGA2 PentiumŪ III and Cyrix
Socket 370 Processors or other compatible Autodetection CPU
Onboard Voltage Regulator Module Provides 1.3V to 3.5V operating voltage
CPU has built-in floating point unit
System bus clock 66/100/133 MHz
PCI bus clock 33 MHz
VIA S3 PL133 AGP set
VIA VT82C686B super-I/O integrated peripheral controller
Two 168-pin DIMM sockets, up to 1GB
Supports 8 MB to 512MB SDRAM memory types
Supports four IDE devices in two channels
Supports PIO mode 0 through mode 4 drives
Supports Bus Mastering DMA mode 2 drives
Supports two Bus Mastering Ultra DMA-ATA 33/66/100 drives
Supports Iomega ZIP or LS-120 removable drives
One floppy disk controller
One Standard/EPP/ECP parallel port connector
Two 16550 compatible serial port connectors
Two USB (Universal Serial Bus) ports on board, two front USB ports by cable
One line-out, mic-in, LAN, vga, 1394 on board,
One COM port by cable
PS/2 mouse connector and
PS/2 keyboard connector on board
One 32-bit PCI slot
One Digital Video ouptup header
One AMR header
Compliant with EPA, APM 1.2 and ACPI
Auto Power on
ATX soft-off power control
Power – on by keyboard and PS/2 mouse
Power – on by external modem ring
Power – on by alarm
Fan off in sleep mode
CPU temperature warning and system temperature detection
CPU and system voltage detection
CPU and secondary fan RPM detection
Mini itx form factor 17 cm x 17 cm (6.7 x 6.7-inch)
Heres a stock pic I found online:
does it come with anything else? case?power?HDD?
no.... just the mobo, ram, cpu, and heatsink
bump for a good seller
can you take a picture with a camera of the whole thing plz?
Project: The 1300$ geek van(1300$ for all, incl. the van cost)
Planning: 50%
Stuff: 20%
Monney: __%
Knowledge: 35%
