Hello everyone, as you can see I'm not much of a poster. I pretty much get all the info I need reading. Ok so I originally planned to use this as apart of a car computer project but decided to just use a laptop instead. The lcd isn't in its factory form because as I stated earlier my intentions were to use it. The reason I cut the speaker portion out of the front casing due to the space issue regarding my center console. I desoldered the male Multi-AV out because I did not want to cut any wires or solder directly to the lcd pcb. Everything is already wired up all you have to do is make the connections and that will be easy because I have labeled every single wire. This lcd will include the other end of the VGA cable. The speaks are also included as well. This lcd is has no dead pixels.
I also am including a GeForce4 MX440 64mb video card. This card is perfect not only because it works with the Psone LCD but because its has more than enough power to play Halo . Try doing that with the Matrox Mystique!
Another item I am including is a Nyko I-type 2. It is a mini usb keyboard and Playstation 2 controller built into one unit. This would be the perfect setup if you get yourself a Playstation 2 to usb adapter. Then run a program called JoytoKey to control your mouse movements with the analog joystick and make any type of shortcuts or program specific funtions with the 16 other buttons. This combo controller is quite possibly the most compact, functional and versatile out there.
I'm looking to get 70 for a packaged deal. If anyone is interested then email me at Masamune1436 at hotmail dot com. Thanks!
