Single Board Computer
This Single Board Computer is used but has been tested and works great. It comes with one Pentium 200 MMX CPU mounted in a socket with a working CPU fan. There is also 32MB of RAM in two sockets. The SBC also comes with a copy of the complete manual which describes header connections to the following on-board subsystems: Intel 82557 based dual-speed ethernet, VGA (up to 800x600)and LCD (I haven't tried this), PC104, one PCI slot, serial/parallel ports, keyboard and ps2 mouse port, 2 USB ports, floppy and IDE controller. There's also a DOC (Disk on Chip) socket, but I haven't tried it.
Also, to make your life easier, the board comes with a nice little power supply and a special IDE cable(2.5" and 3.5" IDE connectors). Attached to the IDE connector is a little 16MB Sandisk flash disk. You can just as easily use a regular IDE drive and CDROM with this cable
Some additional information: The board manual refers to it as "EM-500". The SBC measures 8" x 5.25" (203.2mm x 146 mm). Weight is 340g without CPU/fan. Power requirements: +5v @3A, +12v @ 1.2A, -12v @50mA. Two 16550 RS-232 serial ports. DOC socket supports up to 72MB Flash memory disk. Award BIOS. up to 128MB DRAM. Video controller is CHIPS65550.
http://www.casi1.com/em-500.htm
NEC lcd and touch screen - (with inverter, touch controller) $170
PCI controller from earthlcd - $145
SBC - $85 (with powersupply, manual, drivers, hd cable)
together $400 Thats like a fraction of what its all worth. Like I said I want to sell it together but if you want to call dibs on a part of it and someone else calls dibs on the other part ill sell those people their parts. Basically i wnat to get rid of it all or nothing. And buye pays shipping.
Please PM me if you decide to sell the parts separately... I'm interested in the SBC.
Thanks,
mxyzpltk
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
