bump for a darn good sound card.
I have the X-Meredian.
Auzentech HDA X-Plosion 7.1 DTS Connect Sound Card $85.00 SHIPPED
Selling my DTS soundcard, I have no use for it now since i do not have a DTS decoder, and i am going with the M-Audio Firewire as well.. I would like to get rid of this item at $85.00 SHIPPED!! Item comes with Original Box, and DRIVERS, Optical CABLES, and the PCI Soundcard itself.. Any Questions please ask..
ITEM Features ::
- # C-Media CMI8770 PCI chipset (8CH audio single chip with DTS® Connect and Dolby® Digital Live Real-Time Content Encoder)
- # 8CH codec embedded PCI audio single chip
- # Full-duplex 8CH 24bit/96kHz DAC / 2CH 16bit/48kHz ADC
- # Integrated S/PDIF input/output supports 44.1kHz/48kHz/96kHz sample rate and 16/24bits resolution
- # The world's first DTS¨ Connect logo program certificated PCI audio board
- # DTS® Interactive : A real-time 5.1 encoder that takes any 2 or more channel and encodes it into DTS® bit stream. DTS® Interactive provides a single cable connection via S/PDIF digital audio output to a DTS® enabled surround sound system by encoding all audio into a DTS® compatible bit stream at 1.5Mbps
- # DTS® Neo:PC : An up mixing matrix technology that turns any 2 channel audio into 7.1 surround sound. DTS® Neo:PC, based upon DTS® Neo:6 matrix surround technology, transforms any stereo content such as MP3, WMA or CD audio, into a 7.1-channel surround sound experience
- # Dolby® Digital Live(DDL) Real-Time Content Encoder converts PC audio into a 5.1 channel Dolby® Digital bit stream
- # Swappable dual DIP type OPAMP controlled preamp circuit (4pcs output control OPAMP IC with DIY socket, 2pcs MIC input control OPAMP IC with DIY socket)
- # Max 2.8Vrms full swing analog output gain by unique preamp circuit / incredible powerful analog output, improve dynamic range / SNR
- # Proper OPAMP control circuit (+8V, -8V dual power supply circuit) for high quality audio quality, prevent audio distortion at high volume level
thanks for looking..![]()
-Steph'
Jan Bennett
evening bump..![]()
your not suppposed to bump your own threads. its in the rules
I wish i could use this with my G5
Cant code cause I dont know how, but give me the paint bucket and my eraser and have at you!
