Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: FS Entire System, Everything for $1100.00
    Variable Bitrate nameeri's Avatar
    Mar 2006
    SoCal
    Exclamation FS Entire System, Everything for $1100.00
    Here are the Specs
    7" transflective screen (Xenarc widescreen with remote)
    ------------THE PC--------
    Via C3 1Ghz CPU
    512 MB Ram
    80GB HDD 2.5"
    VIA EPIA PD 10000 mainboard
    6 USB, 4 serial ports
    SB Live 64 sound card
    Caseoutlet Travla c137 case, black
    M1-atx 90W pwr supply
    The following hardware will be included
    -80mm external exhaust fan on top of the chassis cover (keeps the entire system cool, blows hot air from the pc out through the top of the case)
    -XM Direct unit, inside the comp chassis, with cabling for serial port and power, with the antenna
    -RoadRunner temp monitoring hardware with 2 temp probes
    -All wires with molex connectors
    -External USB cd\dvd drive with wiring
    -external Holux GM-210 USB GPS reciever
    The following software is preinstalled
    WIndows XP pro
    Registered copy of StreetDeck, with mappoint 2006(No cds)
    about 5 GB of mp3's, all sorts of music
    1 2 channel AMP
    Power Acoustik 500 Watt
    All power connections run off the m1-atx so you will get clean power to all the components of the pc, including the monitor and the dvd drive.
    You will get all the cabling, usb, power cables, and anything else that i used to install.
    All this for $1100.00. I am not parting this system out. I can take detailed pics of the system. Check out my sig for the install pics as well as the transflective screen. There are links there.
    This is a rock bottom price guys. Its the real deal.
    SO CAL BUYERS PREFERRED! The price does not include shipping which would be pretty darn expensive for all this stuff. Esitmated shipping cost is about 200.00 for UPS ground.
    Civiputer: Dont have one anymore, but here is what is used to be!
    Fusion Brain Creator
    Mar 2005
    offering $20 for the temp monitor and probes
    Maximum Bitrate CJ8501's Avatar
    Jul 2004
    Orland Park, IL
    are you sure you wont part out that transflexive xenarc?
    Mar 2006
    SoCal
    A complete system is much easier to sell. Not going to part it out.
    Mar 2006
    SoCal
    Bump
    Newbie ctowntex's Avatar
    Feb 2007
    Arkansas
    Why are you selling this system? Seems like a great setup.
    I am looking to build a fully loaded carputer (but in a truck). I wouldn't need the amp in this list because I'm going to just go with my stock Bose sound system. Also wouldn't need the XM stuff. If I'm going to have gigs of songs on the carputer, why have XM?
    Have you had any problems with any of it?
    Did I read it right and you did some custom work to the screen? I would put this into the dash or console (I can't decide) and I don't want a screen that is customized to the point where I can't use it.
    Also can you put up pics of the case?
    Mar 2006
    SoCal
    Im selling the car therefore Im selling the system. You cannot use your stock BOSE system unless there is an auxiliary input jack on it. Otherwise, you will need some amps. I have not had any problems on it at all. The screen was modified so that it can be seen in direct sunlight. Also, the screen housing has been removed (most if it anyways) so you would need a mounting for it that covers the areas which are not visible. I can take pictures to explain what I mean. I will post pics of the case asap.
    Mar 2006
    SoCal
    Here is a pic of the PC Case along with the 80MM fan installed on the top of it to help keep the whole system cool.
    Mar 2006
    SoCal
    Here is the monitor in bright sunlight
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    Why Is Shipping $200.00. Are You Shipping The Whole Car Too.
    New Age Garmin - Skin for RR
  1. FS: Award winning Car Audio system
    By RedGTiVR6 in forum Classified Archive
    Last Post: 09-01-2005, 08:37 AM
  2. FS: HTPC Project System
    By migel628 in forum Classified Archive
    Last Post: 08-24-2005, 01:10 PM
  3. FS: Complete Carputer System
    By schapman43 in forum Classified Archive
    Last Post: 08-06-2005, 01:17 PM
  4. FS: Full Computer System (- Memory)
    By nFiniteTuning in forum Classified Archive
    Last Post: 11-01-2004, 12:47 AM
  5. FS: Car Audio Parts (Or full stereo system)
    Last Post: 10-13-2004, 11:47 PM
