ttt
I have up for sale a never powered jl audio 12w7. it has been removed once to test fit in the car and realized it couldn't fit with out some major mods. so it's going up for sale: $400
second, i have 2 eu-700's another failed design plan. they've never seen power but may be a little dusty. they are dual 4 ohm version. I also have a pair of dual 2 ohm versions that i did install in my car but they have never seen power either (my new system has been in design stage for EVER) $40/ea
last is a zapco slx-4. this uses the symblink system that is fully balanced. great if you have zapco amps, some xtant amps, butler tube amps or other amps with balanced inputs. you can also convert it for use on regular unbalanced amps by grounding the -signal wire to the shield. It
s a 4-way active x-over high, hi/bp, lo/bp, and low pass -- $250/bo
*this x-over needs a zapco amp or a zapco psu for power. This unit will be great for someone using an pro soundcard (m-audio, echo, e-mu, etc...) that has balanced outputs.
I have a image dynamics id12v3 dual 4 ohm sub in a corvette flush mount box. this has a couple hundred hours of use on it (300wrms of clean power from my xtant amp) I'd like to sell this as a set but i could part it out.
all prices don't include shipping
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
My Boat Pc worklog
ttt
M10k
My Car Pc Install
My Boat Pc worklog
Free bump for good product and a good guy.
System always under construction
Registered just for your items (although been reading here off an on for years). How much shipped to Vancouver, WA for both EU-700's? Want to give them a try behind my door panels, buts its going to be a tight fit.
PM sent
Edit: Looking for the dual 4's, not the 2's.
