Page 3 of 6 FirstFirst 123456 LastLast
Results 21 to 30 of 55
Thread: Microsoft Streets and Trips 2006 w/ GPS Locator Hardware - $50
  1. #21
    Constant Bitrate stangg172006's Avatar
    Jan 2007
    Morton Grove, IL (Northside Chicago)
    Quote Originally Posted by 2k1Toaster View Post
    No, but some magnetic strips can be had for a couple bucks at HomeDepot along with some clear plastic spray.
    what would the plastic spray be used for?
    '08 VW Rabbit S 2.5
    Carputer Progress:
    Design:[][][][][][][][][][][][][][][][][][] 100%
    Fabrication:[][][][][][][][][][][][][][][][][][]100%
    Installation:[][][][][][][][][][][][][][][][][][][][][][][][][] 80%
    In trouble...
  2. #22
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by stangg172006 View Post
    Waterproofing
    1.9in x 2.9in -- 47mm x 73mm
  3. #23
    Maximum Bitrate Ruffy's Avatar
    Sep 2006
    Georgia
    Benefits of newer units
    1 : time. Sometimes my pharos unit takes forever to get its initial lock. At least it used to when I ran it on a laptop in the passenger seat. seems faster now that im on a powered usb hub
    2 : Accuracy. It's pretty accurate already but at times it simply doesn't know where I am. I turn left and it says I'm still going straight or says offroute because it thinks im in a field somewhere. Mostly happened with MS streets n trips
    3 : Ammount of satellite connections. With newer units you can connect to an insane ammount of satellite. 11!. The most i've ever gotten on my older gps unit is 7. an averge is 4.
    4 : Sirf III provides better building penetration. IE you'll get a signal in places where you didnt get it before. With my current unit its odd for me to get a lock while in my garage with the door closed. But with Sirf III I have gotten 8 satellite lock.
    Car : 00' Chrysler 300M
    Speakers : Rainbow Audio SLC 265 | Subs : Diamond Audio D6 12" Subs X2
    Amp's : Hifonics ZXi 6006 AB | Hifonics BXi 1606 D
    CarPC: HP Laptop AMD Sempron 3000+ | 1.5GB RAM | DVD+RW | 80GB 5400RPM HD | ATI R200 Video
  4. #24
    Mar 2006
    Quote Originally Posted by Ruffy View Post
    1.) I do have my gps unit on a powerd hub, i guess that makes a difference! Mine is speedy.
    2.) Never had that problem. Ever.
    3.) I usually get 7 or 8. What would the advantage of 11 satellites really be over 7 or 8? As long as you have 3, you are good. The rest are backup really. But if 8 satellites get blocked, where are you driving!
    4.) In my garage door closed I get a lock. Not sure how many satellites but I think it is only 3 or 4. But I know where I am in my garage! Do you get a lock in a parking garage? I lose a signal when I go into a parking garage, but since it is all cement and steel, I figured it was normal.
  5. #25
    FLAC is for flaccid parksgm's Avatar
    Dec 2005
    Dallas, Texas
    Better error correction!
    By comparing the signal from 11 satellites, the receiver has a larger "reference" to determine if any of the signals deviate significantly from the mean. Many variables that can affect GPS signal path length, including upper atmospheric conditions and the angle of the satellite above the horizon (the lower the angle, the more atmosphere the signal must go through before reaching your receiver). So, if your 3D fix is based on only 3 satellites, and the signal path length from one of those satellites is excessively long, your position will be in error, and the GPS reciever won't have any way of determining the error exists. Similarly, 11 satellites would provide even better resolution than 7 or 8, although I don't know how MUCH better.
    FYI, from wikipeida:
    Multilateration is commonly used in civil and military surveillance applications to accurately locate an aircraft, vehicle or stationary emitter by measuring the time difference of arrival (TDOA) of a signal from the emitter at three or more receiver sites.
    If a pulse is emitted from a platform, it will arrive at slightly different times at two spatially separated receiver sites, the TDOA being due to the different distances of each receiver from the platform. In fact, for given locations of the two receivers, a whole series of emitter locations would give the same measurement of TDOA. Given two receiver locations and a known TDOA, the locus of possible emitter locations is a hyperboloid (a surface approximately shaped like two cones joined at the points). In simple terms, with two receivers at known locations, an emitter can be located onto a hyperboloid. Note that the receivers do not need to know the absolute time at which the pulse was transmitted - only the time difference is needed.
    Consider now a third receiver at a third location. This would provide a second TDOA measurement and hence locate the emitter on a second hyperboloid. The intersection of these two hyperboloids describes a curve on which the emitter lies.
    If a fourth receiver is now introduced, a third TDOA measurement is available and the intersection of the resulting third hyperboloid with the curve already found with the other three receivers defines a unique point in space. The emitter's location is therefore fully determined in 3D.
    In practice, errors in the measurement of the time of arrival of pulses mean that enhanced accuracy can be obtained with more than four receivers. In general, N receivers provide N-1 hyperboloids. When there are N > 4 receivers, the N-1 hyperboloids should, assuming a perfect model and measurements, intersect on a single point. In reality, the surfaces rarely intersect, because of various errors. In this case, the location problem can be posed as an optimization problem and solved using, for example, a least squares method or an extended Kalman filter.
    Additionally, the TDOA of multiple transmitted pulses from the emitter can be averaged to improve accuracy.
  6. #26
    Mar 2006
    Well yes more satellites is more accurate, but the inherent inaccuracy of GPS is the 1Hz signal. It is too slow to make the more satellites really that more accurate.
    Lets say at t=0, you are at point A on a road which is the centre lane of a 3 lane road driving north. At t=1 which is 1 second later, you will have traveled some distance x north. That distance is the error due to the 1Hz signal. Now take that distance and draw a circle with radius x, and you have the position that you could be in at any time before it samples again. The faster you are going the more error there can be. So you could be at A + x, A - x in the horizontal and vertical planes.
    The only advantage of more satellites in my eyes would be for speeds less than your average error in meters per second. So for this unit I think it advertises 2m-3m accuracy. So unless you are going less than 5-7mph, the error is negligent.
    Does my bassackwards way of thinking sorta make sense? I know what I mean, but hard to put to words...
  7. #27
    Jan 2007
    Waterproofing
    your receiver is mounted on the outside of your car?
    '08 VW Rabbit S 2.5
    Carputer Progress:
    In trouble...
  8. #28
    Mar 2006
    No. But people have done it. You can't just slap it outside. You have to protecxt the connector. Mine is in my dash.
  9. #29
    Jan 2007
    sweet, thats what i was thinking of doing...
    '08 VW Rabbit S 2.5
    Carputer Progress:
    In trouble...
  10. #30
    Dec 2005
    Dallas, Texas
    I understood everything else you said, but what 1Hz signal are you referring to? According to the wikipedia article, the GPS carrier signals are in the 1 to 1.5GHZ range...
    I realize that some GPS pucks may not update the data stream any more frequently than 1/second, but that doesn't mean the timing signal is beng received only 1/second.
  1. Brushed Metal Streets and Trips 2006 skin
    By Mattkins99 in forum Road Runner
    Last Post: 11-07-2008, 11:21 PM
  2. Microsoft streets and trips with GPS
    By carchrism5 in forum GPS
    Last Post: 04-19-2007, 07:53 PM
  3. microsoft streets and trips 2006
    By madehtsobi in forum Classified Archive
    Last Post: 06-13-2006, 02:21 PM
  4. MS streets and Trips 2006 + GPS $80
    By anik321 in forum Classified Archive
    Last Post: 01-30-2006, 12:05 PM
  5. Replies: 0
    Last Post: 03-25-2005, 11:19 PM
