Results 1 to 6 of 6
Thread: WTT: Via Epia V10000 (+cash?) for old dual-lan mini itx motherboard
    Mar 2004
    I have this v10000 and mini itx case lying around, and I'd like to turn it into a router/file server. The problem is, the v10000 only has 1 LAN port and I'll need to use the PCI slot for an SATA controller. I'd just use one of the dual PCI expansion cards, but the case isn't set up for that.
    So, I'm looking to trade for another mini-itx that has 2 on board LAN ports (or one LAN + 4 sata ports)
    Dec 2006
    i'm sure you've thought of this, but what about a usb ethernet adapter instead of dual onboard lan? trust me, if i had a board with dual lan i'd trade but just tossing out the suggestion incase you dont have luck.
    Mar 2004
    That may be an option, but I'd probably cut up the case a little bit before going the usb-ethernet adapter route
    Elsewhere
    I don't believe tat are any miniITX boards with dual LAN onboard.
    Just get a USB ethernet adapter.
    How about the Wiki?
    Banned Motorcity's Avatar
    Apr 2003
    Detroit, MI
    Quote Originally Posted by DarquePervert View Post
    HUH?
    here's about 20 different boards, all mini itx, all dual lan.
    There are plenty more out there too.
    http://www.logicsupply.com/product_i...roducts_id/737
    http://www.logicsupply.com/product_i...roducts_id/612
    http://www.logicsupply.com/product_i...roducts_id/739
    http://www.logicsupply.com/product_i...roducts_id/611
    http://www.logicsupply.com/index.php/cPath/78_75
    http://www.logicsupply.com/index.php/cPath/78_55
    Jan 2006
    How about that....
  1. Replies: 3
    Last Post: 05-06-2005, 11:29 PM
  2. Via Epia ITX motherboard BIOS Image
    By iansalfaproject in forum General Hardware Discussion
    Last Post: 03-15-2005, 12:25 PM
  3. Bargain!! Via Epia Nehemiah 1ghz Mini Itx Mainboard
    By dave0109 in forum Classified Archive
    Last Post: 05-26-2004, 07:40 AM
  4. WTB: MIni ITX or Shuttle FV24 or FV25 motherboard
    By kendrick in forum Classified Archive
    Last Post: 03-09-2004, 09:29 PM
  5. VIA EPIA Mini ITX beeping problem
    By tbdombrosky in forum General Hardware Discussion
    Last Post: 06-28-2002, 11:31 PM
