If you need help determining which power supply to use, then try posting in the power supply forum. In a nutshell, you need to determine/estimate how much current the system uses on the 3.3V, 5V, and 12V rails at 100% CPU load, and then pick a power supply that can supply that much current with a reasonable safety margin. There is an excellent FAQ for this in the power supply forum...I think it's a sticky.
Good luck.
LinkBack URL
About LinkBacks
