Results 1 to 3 of 3
Thread: 600watt inverter
    Mar 2001
    Cincinnati, Ohio
    600watt inverter
    I have a 600 watt inverter, runs good, 3 outlets, its blue.
    Has 4 gauge wire jacks in the back. takes a 70 amp fuse.
    The front has been taken off, and the switch disabled, and it now uses 2 wires running out the front which can be controlled with a relay to turn it on when the car comes on.
    I'm asking 100$ plus S&H, I paid 120$
    Its never been used to power anything, although it has been installed in my old S10, so there is a little wear and tear from the screws on the mounting plates, but is in still good condition.
    Make an offer though, I may bite.
    Clarion 200watt head unit w/ Aux in.
    Kicker 800watt 4 channel amp
    In a 96 Grand Prix SE.
    May 2002
    Hawaii
    I need a converter that can handle at least 8 amps of current.
    Let me know the name brand and whether it can handle that kind of drain and you may have a deal.
    Mar 2001
    Cincinnati, Ohio
    Its a Statpower Portawatts 600 I believe.
    I'm sure it can handle 8amps
    http://www.statpower.com/pwtz600.htm
    They guarentee it can run a 5amp drill, but thats a different kind of draw than a Power supply, right? So it should work fine.
