Results 1 to 10 of 10
Thread: Sproggy Modification, changing the dimensions
    Jul 2002
    Washington
    Question Sproggy Modification, changing the dimensions
    Is it possible to change the dimmensions of the sproggy power supply by using a different pcb and putting all the same parts on in slightly different places. I need the power supply dimmensions not to be higher than 50mm and not to be wider than 170mm. i want to get depth to be as small as possible so (HxWxD) = (50x170x?) or if there is another power supply similar to the one i described that already exists then what is it, I have looked but found none. I am aming for less than 30mm for the depth even less than that if possible not sure if it is just have to hope i guess.
    May 2002
    Sef'Kylar
    the power supply that comes in this case meets those specs.. just keep in mind you need to feed it 12v 5a regulated.
    aka Kumaneko
    "Don't make me moderate your ***!"
    Maxima of Doom - project thread - photo gallery
    mp3car system is currently FUBAR and finances do not allow for a correction of that situation
    Real computer hackers use a rotary cutting tool on their motherboard.
    Maximum Bitrate GuRuGoD's Avatar
    Jun 2002
    Omaha, Nebraska
    also keep in ming that that psu is a whopping 60 watts
    FLAC mp3z24's Avatar
    Apr 2001
    Chicago Suburbs
    the sproggy only puts out something around 60 (off the top of my head)
    ~mike
    Single Member of the "1000 Post and No MP3 Car" Club
    PROJECT ON INDEFINATE HOLD... BOUGHT A HOUSE
    2000 Cavalier Z24 [###-------] Only 30% Done ... Still
    Jul 2002
    Gjøvik, Norway
    And you where talking about double posts, Mike
    May 2002
    Sef'Kylar
    It's not a double post BOTH psu put out about 60w
    aka Kumaneko
    Jul 2002
    Gjøvik, Norway
    oh, sorry... think i'll have to read the posts from now on
    Jul 2002
    Washington
    so the DC-DC power supply that comes with this board does not regulate the power like a sproggy would? if not then what could i do to regulate the voltage in? i need small and low heat ideas.
    Jul 2002
    Washington
    would this work to regulate the power supply or is there a different kind that would work better?
    http://www.maplin.co.uk/products/det...10&modulecode=
    Apr 2001
    Chicago Suburbs
    hehehe just kidding!!! (i like using that smilie)
    thanks... that is what i was trying to say, but i was too lazy to clarify.
    ~mike
