I could be wrong as it was a while ago that I read the manual.. but I would guess that the lockout period just prevents the shut down signal being sent while it is still starting up. Once that timer has run out it should send the signal if any of the other shut down conditions are now met. IE the car is now turned off or worst case when the voltage drops below the low voltage threshold.
But I would need to read the manual again to check: http://carnetix.com/support.html
LinkBack URL
About LinkBacks
