Results 1 to 10 of 10
Thread: Using DLYON - Amp thump
    Sep 2008
    Happy with my P1900 so far. One of the last problems in my carpc installation is the Amp Thump - I can't seem to get rid of it.
    I tried the DLYON (blue wire), but there's no change. Amp supports "remote", and it was working fine with previous carpc (M2 psu) - there was no thump at startup.
    Maybe I set the jumpers wrong. What would the correct jumper settings be? JP4 - 2,3 pin (DLYON) ... others?
    My setup is based on an 19v Zotac ION Mag, no extra harneses.
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    I'm not sure what to suggest other than re-read pages 27-29 of the manual and double check your jumper settings against those instructions. My 1900 works perfect for this job.
    Sep 2008
    I already did that. So just in case I failed to understand the config correctly - would you be so kind to write your jumper configuration? Do you have only one cable (blue) going from PSU to AMP?
    Sep 2008
    I tested some more today. The thump comes after initial windows loading (from hibernate); just before desktop is shown. This seems a bit weird, as the soundcard is on board. It's like the loading drivers make this thump. Out of ideas ATM.
    Maximum Bitrate pcpete's Avatar
    Mar 2008
    Toronto Canada
    It's been a while , but when I used this unit, they changed something when they updated the fw and dlyon stopped working...they had it documented on their forum or something...
    I could be wrong but i remember going through this as well...
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    I was going to go out to the truck, and snap a pic of the 1900 with my jumper settings, I just didn't get a chance yet, the truck has been tied up. I'll try tonight or in the morning. Have you checked your amp to see if it appears to be delaying in powering on?
    Sep 2008
    Thank you for the info.
    I think the DLYON delay of 3 seconds works - I checked the AMP "ON" light. The problem must be in the drivers somehow. As stated in previous post, the "pop" comes right before windows startup/wakeup is finished. That's about 15 seconds after car ignition start. I checked all the windows settings; put everything to "off" (audio input and such), but nothing is changed.
    Another useful info might be that AMP is connected to the "headphones" output jack, which is the only analog sound output available on ZOTAC ION MAG. I'll try my luck in finding a better driver..
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    This may not help now but here it is since I've got it JIC.
    Name:  P1900 setup 3-12.jpg
    May 2004
    dotraw, just to be clear does it happen from a cold boot AND from hibernate, or just from hibernate?
    Sep 2008
    Quote Originally Posted by PhilG View Post
    Thank you. I'll check it out anyway.
    Quote Originally Posted by digital509 View Post
    Both.
    I tried to update the drivers yesterday. It was "popping" while installation was progressing. The output seems to be amplified too much. On the AMP INPUT I've changed from medium to the the minimum setting; it helped somewhat.
    This probably belongs to another forum now; nevertheless: does anyone have any ideas how to fix this annoying issue? Software? Some weird "magic" box on the PC output? USB external card? Different AMP that you can connect to the OPTICAL or HDMI output?
  1. amp thump
    By noshell in forum Car Audio
    Last Post: 08-21-2009, 11:56 AM
  2. Will DLYON work with this amp?
    By hutacars in forum Car Audio
    Last Post: 08-20-2009, 12:00 AM
  3. 2140 DLYON is flipped
    By hari-bhari in forum Power Supplies
    Last Post: 01-07-2009, 11:58 PM
  4. M4-ATX PS and amp thump help
    By soloxp in forum Power Supplies
    Last Post: 04-20-2008, 10:24 AM
  5. Help Me Get Some Thump!
    By cobalt_girl in forum Car Audio
    Last Post: 07-02-2007, 02:23 PM
