Results 1 to 5 of 5
Thread: P1900 output issue (there is not power out)
    Aug 2009
    Houston, TX
    Question P1900 output issue (there is not power out)
    Hi all,
    It's been a while. I've enjoyed the P1900 since 2009, but mine recently died so I purchased a new one from mp3Car.
    I've set the dern thing up as I did before minus the 5v regulator add-on because I no longer use it. In spite of this, the power regulator does not function properly. I've checked the input voltages and they appear correct. The only response I get is a short series of flashes from the P1900. Before and after the flashes, the light is off.
    Any ideas?
    Sound System () 100%
    Power System () 100%
    MacMini Setup () 100%
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    There is an internal blade fuse on that supply, maybe check that, I've had mine blow once. Also I think the light sequence you see happening can be cross referenced to a diagnostics chart in the installation manual IIRC.
    Aug 2009
    Houston, TX
    Hmm. The fuse is still intact. I had an old one blow on my first P1900.
    What diagnostic chart? And what IIRC manual?
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    page 40 of the installation manual here: http://www.carnetix.com/installation...ManualV2_1.pdf
    IIRC= if I remember correctly
    Aug 2009
    Houston, TX
    IIRC...got it.
    There is no flash sequence that corresponds to what mine is doing. I'll take a video this weekend and post that for help in the diagnosis.
  1. P1900 Power Output Flaky?
    By TTUStephen in forum CNX-P1900
    Last Post: 07-25-2012, 09:51 AM
  2. FS: Carnetix p1900 with 3rd Output 5v attachment!
    By skippy911 in forum Classified Archive
    Last Post: 10-22-2006, 04:46 AM
  3. Carnetix P1900-Power Output-Shutdown Question
    By froalskiner in forum Power Supplies
    Last Post: 07-18-2006, 12:11 PM
  4. Replies: 7
    Last Post: 12-09-2005, 11:38 AM
  5. Replies: 30
    Last Post: 08-16-2005, 02:56 PM
