Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: PSUMoni, P2140 and Windows 7
  1. #21
    Jun 2008
    DC Burbs
    Quote Originally Posted by DaveDog View Post
    check bios setting for resume when power restored
    I would, but I am using a 2010 Mac mini, i dont think these have bios? please correct me if i'm grossly incorrect.
  2. #22
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    That is true the Mac Mini has an EFI firmware rather than a PC style BIOS.
    How do you have your power button wired? macpac wire? or some other method?
  3. #23
    Jun 2008
    DC Burbs
    Quote Originally Posted by Machinehead View Post
    hi I have a new 2010 model mac mini, so the macpac stuff doesnt work with my p2140 and mac mini
    right now, i do not have anything wired to my power button, but i was thinking about wiring the acpi wires to the my positive and negative outputs and moving the jumper in JP3 pins 1 2
    am i on the right track?
    it wont resume after hibernate unless i physically hit the power button.
  4. #24
    Jun 2007
    Without a connection to the isense cable the mac won't turn on at all which is why you have to push the power button.
  5. #25
    Jun 2008
    DC Burbs
    Thanks for the info Machinehead, but can you explain how i should connect the isense cable? to where?
    i've tried to connect it to the positive lead to mac from the p2140 white output isense cable.... is this right?
  6. #26
    Jun 2008
    DC Burbs
  7. #27
    Jun 2008
    DC Burbs
    so i bought the mac mini power kit and installed the y connector with a push button. this actually works with the push button, but i still cannot get a configuration to work in order to return from hibernate automatically.
    in other words, it will hibernate, but will not return to hibernate unless i physically hit the power button.
    how can i wire it up so that it will return when i turn on the ignition. ive tried wiring the green acpi cable from the p2140 to the green cable of the mac power kit and the black (ground) to the black cable. the white isense cable still remains to be a mystery to me. how can i set this up?
  8. #28
    Jun 2007
    Do you have a working link to the installation instruction PDF for that power button kit?
    The link in the store doesn't work.
  1. PSUMoni with Windows 7
    By mikeTDI in forum Power Supplies
    Last Post: 01-06-2011, 08:54 PM
  2. P2140 Windows 7
    By sckeLL in forum CNX-P2140
    Last Post: 02-07-2010, 04:32 PM
  3. Replies: 0
    Last Post: 02-02-2010, 11:52 AM
  4. P2140 Setup Question
    By mdd5148 in forum MacCar
    Last Post: 06-30-2008, 10:57 PM
  5. Carnetix P2140 Standy issue
    By Kimota in forum Power Supplies
    Last Post: 08-03-2007, 11:48 AM
