Results 1 to 2 of 2
Thread: CNX-P2140 Device can not start (Code 10)
    Low Bitrate Gecko483's Avatar
    Feb 2008
    Anaheim, CA
    After installing a new CarNetix CNX-P2140, I attached the USB cable from the CNX-P2140 to the Computer. When I installed the PSUmoni software and configured the drivers the device has an error. The error is: "The device can not start (Code 10)". By reading the CarNetix forums they say to flash the 2140 with the new firmware v1.4.4 but if I cant connect to the PSU how can I flash the new firmware? the PSU was purchased from mp3car.com. The reason why I need the USB cable and monitor software is because I would like to be able to change the startup delay timer. I would also like to monitor the PSU voltages while the computer is running.
    Feb 2008
    Anaheim, CA
    Finally found a solution after trying 3 different computers, the problem here lies in the 64 vs 32 bit OS. Installing PSUmoni2140 on a 32 bit windows XP system yielded no errors and I was able to upgrade the firmware and change all the start up timings.
    Upgraded to the 1.8.02 firmware
    ACPI delay to 10 seconds
    ACPI Signal to 1 second.
  1. p2140 does not start up correctly
    By pnyboy27 in forum Power Supplies
    Last Post: 05-14-2008, 01:09 AM
  2. Anti Engine start based on access code!
    By Naesstrom in forum General Hardware Discussion
    Last Post: 07-02-2007, 03:59 PM
  3. Auto Start Up and Shutdown with Carnetix P2140
    By stupidjunior in forum Power Supplies
    Last Post: 05-17-2007, 05:01 PM
  4. Cant seem to get mobos (10 of em) to boot any device..
    By crazyshaxs in forum General Hardware Discussion
    Last Post: 03-22-2002, 12:59 PM
