Results 1 to 6 of 6
Thread: Integrated antenna
    May 2010
    Integrated antenna
    I have a VW caravelle with the antenna integrated in the windsheild.
    And when the p2140 starts the radio blurs out. The signal seems to wipe away by the p2140.
    Is there anything i could do to shield it or something?
    Or should i get a roof antenna if i want to have the radio and the p2140 running at the sam time.
    regards
    Bruno
    Dec 2007
    Colorful Colorado
    ::BUMP:: for a similar issue.
    Newbie piglith's Avatar
    May 2008
    Good ground, Isolated +12 line to the 2140.
    Dec 2007
    Colorful Colorado
    Tried that. Grounded to chassis and/or battery. Oversized power feed lines direct from battery. These three things helped to a small extent, but did not quash the RFI.
    Ferrite beads on all inbound and outbound lines for the PSU didn't seem to help a bunch either.
    My guess would be that the CNX is doing some high-speed switching that is based around 150mhz and that is what is generating the RFI.
    It could be that the way my power cables were ran were an issue, however I still saw the problem when I was using a small lead-acid battery to power the CNX next to it insted of from the main battery in the truck.
    Raw Wave
    Nov 2009
    Antenna ground should be to the body, not battery - ie, groundplane. (But RF amps should be power-grounded to the battery...)
    And converter power switching is (should be!) sub-MHz - no where near 150Mhz.
    Not that that means there is no 150Mhz noise, but it's probably at a lower frequency maybe IFs (455k; 10.7M etc).
    I'm tempted to suggest small caps for such high frequencies (else in-line beads), but after a recent problem that proved to be a ground loop...
    Dec 2007
    Colorful Colorado
    Forgive me if I was unclear. I tried grounding the PSU to the battery direct, to chassis very close to PSU and both at the same time.
    As for the switching speed, I am curious what is actually being done. I will note the radio is not of the best quality so I cannot exactly rule out that the interference is messing with the IF or if its making it past the Freq-Mixer.
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 10:30 PM
  2. The search for a good am/fm antenna thread, all welcome.
    By greatwhite in forum General Hardware Discussion
    Last Post: 02-05-2010, 03:09 PM
  3. Replies: 9
    Last Post: 04-22-2006, 08:22 AM
