Results 1 to 6 of 6
Thread: Not enough power on secondary output??
    Nov 2009
    Canada
    I'm coming from my P2140 12V secondary output to my Xenarc 7" touchscreen. This gives me a crazy amount of lines going through my screen. Is this too much power, or lack of power coming from the P2140?
    thx mc
    Elsewhere
    No, it's either RFI or a grounding issue.
    How about the Wiki?
    Dec 2007
    Sydney Australia
    If your screen is a 12V model then it will only draw as much power as it needs. It can never get fed "too much power" only too much voltage.
    Which Xenarc 7" do you have ?
    Most only draw upto 10W@12V but the 706TSA draws upto 25W@12V which is a lot closer to the maximum secondary output of the P2140 being 36W@12V.
    Check your output is set to 12V and not 5V and also that there is no AC voltage on it from a faulty component. What does your PSUmoni power supply monitoring application show ? You should make sure all the indicator pointers are in the green zones.
    Have you tried powering the screen from the mains adapter ?
    VIA Pico ITX, M2-ATX clone, 7" Seform 800x480 LCD Touchscreen, Dual 2x75WRMS Mini Amps, IDE-CF & SATA-CF adapters, 8GB (Sys) & 32GB (MP3s) CF, ELMscan5USB, Slot-load DVD, Craig Brass DAB+/FM USB module, Odyssey Navigator
    Build 90% Apps 50% Install 10%
    Nov 2009
    Canada
    Just got my monitor back issue still exists
    My Xenarc is Model # - 705TSV
    which is 9V - 30V i believe
    I don't use PSUMoni because it doesn't work in Windows 7. I do however, have the tray app installed now which might work i will check all the outputs if i can.. Otherwise I will hook my p2140 up to XP machine.
    Not sure that I still have the adapter that came with the monitor. Does it have a filter on it? That might be my problem as well. Anyways i'll update tn
    Nov 2009
    Canada
    now i get blue screen of death when i try to install the new drivers for my P2140 argggg. . hopefully ill get some time to taking it out
    Maximum Bitrate DaveDog's Avatar
    Mar 2004
    Greenacres, WA
    I use the drivers that come with the tray app. they are Win7 compatable. I even can get Psumoni to run using those drivers
    TruckPC - gutted, being used for test setup
    BoatPC - Update coming this spring
    BlazerPC - PS keeps killing battery
  1. FAQ: Installing a Mac Mini in Your Car
    By Bugbyte in forum The FAQ Emporium
    Last Post: 06-11-2011, 08:12 PM
  2. install mac mini
    By ssteger in forum VaultWiki
    Last Post: 02-09-2010, 02:47 PM
  3. P2140 Secondary Output not Powering
    By noobified in forum Power Supplies
    Last Post: 07-07-2008, 03:55 AM
  4. Intel 3945BG Mini-PCI-E Output Power?
    By Caelric in forum Wireless Communications
    Last Post: 02-24-2007, 12:06 PM
  5. Replies: 7
    Last Post: 12-09-2005, 10:38 AM
