CNX-P2140 will not shutdown
Configuration:
JP1 - set for 12v
JP2 - set for 5v
JP3 - no jumpers
JP4 - Config 2 - (12v / 5v)
JP5 - ACPI / PC
Inputs
Red Input x2 - Car battery
Black Input x2 - Car ground
Yellow Input - Car ACC
Outputs
Red x2 - Power to picoPSU-150-XT
Black x2 - Ground to PicoPSU-150-XT
all other outputs not connected but terminated
Flashed to v1.8.3 firmware
Computer powers up fine, but when ignition is cut P2140 will not enter shutdown.
There is a 3.5-4.0v signal on the ignition line coming from within the PSU.
I measured the input lines with the P2140 disconnected to confirm this.
It seems this low voltage is holding the PSU in the RUN mode. Do I have a defective P2140? The max power draw on the 2140 is only 95 watts. If i shut down the computer manually and then disconnect the P2140 from the computer it then enters shutdown mode. How is this voltage getting back to the ignition line?
If you need any other information please let me know.
