Results 1 to 2 of 2
Thread: JP6 wires or jumper ?
    Jan 2010
    before I put my P2140 in a difficult to access location I need a clear answer on this.
    I have the green and white wires connected to my mini-itx motherboard power switch. Does a jumper go across the 2 posts on JP6, put nothing there or ????
    I'm assuming by putting a jumper across them you are initiating a signal out the green/white when power comes on.
    Elsewhere
    If the wire from JP5 to the motherboard's power switch header triggers power-on & power-off properly, then you don't need anything connected to JP6.
    How about the Wiki?
  1. M2-ATX jumper settings
    By Gmello in forum M2-ATX
    Last Post: 01-29-2011, 05:28 PM
  2. Replies: 2
    Last Post: 10-22-2007, 06:03 AM
  3. M1-ATX J8 jumper, is it grounded?
    By civic5zigen in forum Power Supplies
    Last Post: 09-22-2005, 08:54 PM
  4. HDD jumper settings
    By Skipjacks in forum General Hardware Discussion
    Last Post: 01-12-2005, 03:01 PM
  5. 2 pin jumper cables?
    By zootjeff in forum Power Supplies
    Last Post: 02-13-2003, 06:10 AM
