Results 1 to 8 of 8
Thread: Front End - Form Size
    Apr 2007
    Hi there,
    I am looing to start attacking developmenet of my new front end - however, I do not my LCD yet and are unsure of how big to make the form in Delphi (to suit my LCD).
    I will be using [LEFT]an 8" LCD.
    How do most people set up there base form? I obviously want it to take up the whole 8".
    Thanks for your help.
    Apr 2007
    ok, but how big are they normally?
    Cheers.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    OK, most people have 7" screens.
    And they will either set the resolution at 800x600 or 848x480
    FLAC SFiorito's Avatar
    May 2004
    or just set the form to start up maximized so you don't worry about resolution
    Apr 2007
    I was more worried about how much screen real estate i had to play with more than anything else.
    Maximum Bitrate DeltaFX's Avatar
    France
    Most common res are 800*600 and 800*480.
    Don't forget to :
    - ask zindoz to hide the taskbar
    - Set your form(s) with no border
    Try to make your front-end selfcontained, not depending on a precise version of wmp ( real coders use bass.dll ), or a certain OS, or a certain version of the MDAC, or whatelse. If that's not possible, allow the user to deactivate the function
    There are navigation programs that runs perfectly fine on a win98se 450Mhz K6-2
    Remember that win98/Me are fully capable 32bits OSes too, and much more suited for small puters than vista), try to be retrocompatible.
    From an ergonomic point of view, make sure a transistion between to screens takes less than 10ms, avoid any form of user confirmation for an action while driving, avoid error messages (create logs instead)
    Now Galileo is real. Muhahahahaha :p
    Apr 2007
    Great advice!
    thanks for that, consider it all taken on board!
  1. 100% Plugin based Front End
    By custardbomb in forum Software & Software Development
    Last Post: 10-07-2005, 01:17 AM
  2. Searching for the right Front End
    By ninjatill in forum Newbie
    Last Post: 09-10-2005, 03:47 PM
  3. which front end for no touch screen?
    By turbochris in forum Newbie
    Last Post: 08-30-2005, 10:59 AM
