Results 1 to 10 of 14
Thread: Direct boot into front-end, XP GUI on exit
    Sep 2006
    Cornwall, England
    I have read a lot of people want to boot directly into their front-end without running the wXP GUI. It has been said that if you have the registry entry to shell into your front-end, when you run explorer.exe, it only brings up the windows explorer window, not the entire GUI. After playing around with it for an hour, I found that if you boot into your front-end and then edit the registry entry in .....winlogon\shell and enter 'explorer.exe', then run explorer.exe, the full XP GUI will pop up, not just a windows explorer window.
    Because I have programed my own front end in VB.NET, I can write code into it to change the registry entry.
    What I do first when my front-end loads is change the registry entry to shell explorer.exe
    When I click the exit button, it shells explorer.exe, then re-writes the registry entry to shell my front-end, then ends the front-end:
    In the main form load_Load:
    Dim WSH
    WSH = CreateObject("WScript.Shell")
    WSH.RegWrite("HKEY_LOCAL_MACHINE\Software\Microsof t\Windows
    NT\CurrentVersion\Winlogon\Shell", "explorer.exe")
    In the 'exit' button:
    Shell("explorer.exe")
    Dim WSH
    WSH.RegWrite("HKEY_LOCAL_MACHINE\Software\Microsof t\Windows NT\CurrentVersion\Winlogon\Shell", My.Application.Info.DirectoryPath & "\Vive.exe")
    End
    Vive.exe is the front-end executable.
    This seems to work fine, hope this helps some people
    ViVE - Volkswagen In Van Entertainment:
    VoomPC 2, VIA C7 2GHz
    7" Lilliput
    120Gb Sata drive
    1GB RAM
    [||||||||||] 100% - Planning
    [||||||||||] 100% - Software coding
    [||||||||||] 100% - Built
    (Always tweaking!)
    Maximum Bitrate jonessc's Avatar
    Nov 2006
    Wales, UK
    Great idea!
    so all your literally doing is importing registry keys to get the relevant menus, i always thought a restart would be needed b4 the changes would take effect.
    You may wanna change your title to How to!
    CarPuter Progress:
    Planning:-----> [||||||||||] 100%
    Hardware Buying:-> [||||||||||] 100%
    Software:-----> [||||||||||] 100%
    Installing:-----> [||||||||||] 100%
    Current Project= Making skins in photoshop...
    Sep 2006
    Cornwall, England
    Yeah. It's strange that when the Shell entry is "your front-end.exe", and you try and run exporer.exe you only get the explorer windows. And if you change the entry to "explorer.exe", then run explorer.exe, you get the full GUI.
    I thought that this entry is only 'looked' at when XP starts, until I played around with it.
    7" Lilliput
    120Gb Sata drive
    1GB RAM
    (Always tweaking!)
    Nov 2006
    Wales, UK
    Quote Originally Posted by portreathbeach View Post
    I might give it a go, without the correct explorer loading you dont get a start menu/taskbar if im thinking correctly only the file exporer and ability to use taskmgr, i use to boot to front end, but found it annoying when i wnated to get back into windows!
    CarPuter Progress:
    LTi
    LTi is offline
    Jul 2007
    Hungary
    Frontends GUI on startup, without explorer running
    Dear friends,
    The easiest and safest way to do such (mentioned in title) thing is to create and use Policies with the Policy Editor,
    which works only on "XP Professional". I mean the sw works on all XP versions, but policies can not be applied only on XP Pro.
    What is great beside a lot of things is that you can tie the frontend only login to a selected user so any problem should happen you can have the admin or any other user to log into and fix things. Also while the frontend is running and you would like to have explorer you can start it up anytime.
    Regards
    Sep 2006
    Cornwall, England
    The main reason that I alter the 'Shell' in the registry is that if you shell to your front-end, and try and run explorer.exe, you only get the explorer window. You have to change the registry entry to explorer.exe while in the front-end to allow the full GUI to load. I don't really understand why this is, but it seems to work.
    You would have thought that after XP looks at the 'shell' entry and runs the front-end, it wouldn't look at it again, but it does, and explorer.exe will only run the full GUI if the 'shell' entry is explorer.exe.
    7" Lilliput
    120Gb Sata drive
    1GB RAM
    (Always tweaking!)
    Constant Bitrate krnpimpsta's Avatar
    Dec 2007
    DC Metro area
    Noob question here,
    What is the benefit of starting your HU software this way, versus just adding it to the startup folder, where it loads after explorer/etc?
    Sep 2006
    Cornwall, England
    Boots quicker, XP doesn't have to load the GUI and programs in the task bar.
    7" Lilliput
    120Gb Sata drive
    1GB RAM
    (Always tweaking!)
    Dec 2007
    DC Metro area
    Thanks.
    Newbie DVLRCR's Avatar
    Jul 2005
    West Auckland, New Zealand
    Are there any side affects? e.g. wireless network not loaded etc?
    Regards, Neil
    Carputer HW Status: 70%
    Carputer SW Status: 15%
    Microcontroller HW Status: 20%
    Microcontroller SW Status: 10%
  1. Problems with XM input thru any front end
    By CyberLogic in forum Software & Software Development
    Last Post: 05-07-2006, 02:49 PM
  2. This is an awesome front end, and here is why:
    By WhiteRabbit in forum NeoCar Media Center
    Last Post: 08-27-2005, 10:43 PM
  3. BASIC Stamp question
    By Banderon in forum General Hardware Discussion
    Last Post: 05-07-2004, 09:33 AM
  4. So many Front Ends now, we need a Front End to load the Front Ends.
    By LESLIEx317537 in forum Software & Software Development
    Last Post: 04-09-2004, 05:53 AM
  5. GUI Front end skins
    By BMW318_Mp3 in forum Software & Software Development
    Last Post: 08-29-2002, 05:48 PM
