Results 1 to 4 of 4
Thread: [VB6] Problems with MsComm in a DLL plugin for Road Runner
    Newbie DaveDevil's Avatar
    Jul 2007
    Hy everybody...
    I'm becoming mad with a problem that I can't solve:
    in my visual basic 6 program, that is a plugin for road runner (a DLL),so it has not a Form, and I must use the com port.
    I initialize it with these two commands:
    Code:
    Dim MsComm1 As MSCommLib.MSComm
    Set MsComm1 = New MSCommLib.MSComm
    but while executing, the program says: "utilizzo non valido della parola chiave NEW", in english: "incorrect use of the keyword NEW"
    I searched help in google, but purposed solutions can't solve my problem...
    I tried this:
    1.
    Code:
    Dim MSComm1 as MsComm
    MSComm1 = CreateObject("MSCommlib.MSComm")
    but the program says that it can't create the ActiveX object
    2. writing only
    Code:
    but this time the program says that the variable is not defined...
    someone help me please!!!
    Maximum Bitrate Robby BMW's Avatar
    Aug 2005
    Italy
    Create an invisible Form and place the MsComm control in it
    _______________________________________
    Car installation 95% [■■■■■■■■■■■■■■■■■■■]
    Current project: Parking sensor USB interface
    Jul 2007
    uhm... but how can i "load" the form, if i'm using a DLL?
    I must load a invisible form every time that I call my function, and at the end close it?
    or simply when the skin loads, do all the events in the dll?
    Jul 2007
    i think that i solved the problem:
    in the net i found this
    Code:
    that i pasted directly in my program.
    but it's not correct, because in the second line i create an object that is already existing.
    so i had to modify in this:
    Code:
    Dim MSComm1 as Object
    and it works perfectly!
    Thanks everybody!!!
  1. Replies: 4
    Last Post: 12-27-2006, 04:22 PM
  2. Extension plugin problems
    By festy in forum Road Runner
    Last Post: 06-23-2006, 07:20 PM
  3. problems with video + road runner.
    By nealric in forum Road Runner
    Last Post: 01-14-2006, 10:37 PM
  4. Problems with Markus Zehender's plugin SA
    By bombboyer in forum General Hardware Discussion
    Last Post: 11-25-2002, 03:58 PM
  5. Lorty's plugin display problems, really weird
    By dudah85 in forum Software & Software Development
    Last Post: 08-08-2001, 12:59 AM
