download WOSB (free)
Code:wosbExe = "c:\WakeupOnStandBy\wosb.exe" ' Path to wosb.exe sleepTime = 15 ' Sleep time in minutes Set oShell = CreateObject("WScript.Shell") Set colMonitoredEvents = GetObject("winmgmts:").ExecNotificationQuery("Select * from Win32_PowerManagementEvent") isHibernate = False suspendTime = Now resumeTime = Now Do Set objLatestEvent = colMonitoredEvents.NextEvent Select Case objLatestEvent.EventType Case 4 ' Suspend If Not isHibernate Then suspendTime = Now oShell.Run wosbExe & " /systray /run tm=+" & sleepTime & ":00", 0, False End If Case 7, 18 ' 7 - Resume, 18 - Automatic Resume resumeTime = Now If Not isHibernate Then diff = DateDiff("n", suspendTime, resumeTime) If diff >= sleepTime And diff <= sleepTime * 2 Then isHibernate = True oShell.Run wosbExe & " /closeall", 0, False oShell.Run "rundll32.exe powrprof.dll,SetSuspendState", 0, False Else isHibernate = False oShell.Run wosbExe & " /closeall", 0, False End If Else isHibernate = False End If End Select Loop
