Results 1 to 6 of 6
Thread: Pointers in Delphi?
    Vendor - Qube colin's Avatar
    Dec 2006
    Pointers in Delphi?
    I know this is a long-shot since hardly anybody uses Delphi nowadays, but in a sad effort to make an efficient program, Im begging.
    Heres my structures:
    Code:
      SongList: Array of TSong;
      Albums: Array of TAlbum;
      Artists: Array of TArtist;
    TSong = record
        ID: Integer;               // ID for loading from cache and flash
        Title: String;
        Artist: String;
        Album: String;
        Filename: String
      end;
      // Album has a reference to the Song stored in the master song list
      TAlbum = record
        Title: String;
        Artist: String;
        Picture: String;
        Path: String;
        Songs: Array of ^TSong;
      end;
      // Artist contains a reference to the Album stored in the master album list
      TArtist = record
        Title: String;
        Path: String;
        Albums: Array of ^TAlbum;
      end;
    There is a main list of Songs, Albums and Artists.
    In the artists list, there is an "Albums" element which is an array of POINTERS to objects in the main albums list.
    It sounds confusing but the concept is simple.
    Anyway, I parse all my music fine. When I try to access it though, I get messed up errors:
    Code:
    Faber Drive
     - 1 Albums
        - 33
    Gorillaz
     - 4 Albums
        - 34
        - 35
        - 36
        - 37
    Guns N Roses
     - 6 Albums
        - 1934974067
        - 543908705
        - 2
        - 1667855221
        - 1226863221
        - 1886203507
    Iron Maiden
     - 23 Albums
        - 1432107587
        - 541991027
        - 1936617321
        - 0
        - 1819231068
        - 1934974067
        - 543449445
        - 2
        . ETC
        - 1432107587
    Jack Johnson
     - 5 Albums
        - 541991027
        - 1936617321
        - 33685504
        - 1819231068
        - 1934974067
    Jay Z & Linkin Park
     - 1 Albums
        - 1701212773
    Linkin Park
     - 3 Albums
        - 2
        - 1667855221
        - 1226863221
    Meatloaf
     - 6 Albums
        - 1886203502
        - 1432107587
        - 541991027
        - 1936617321
        - 33832632
        - 1819231068
    Rage Against The Machine
     - 4 Albums
        - 82
        - 83
        - 84
        - 85
    ** Those are accessed by Artists[I].Albums[J].ID so it should be listing the album's ID number. It works perfectly fine until a random point at which the numbers get all screwed up!
    Any ideas?
    Mar 2006
    I'm guessing you are allocating memory when constructing the arrays? Its also looks like you are not de-referncing the pointer arrays when accessing them...
    My advice is to use the following:
    TSongArray : Array of TSong;
    TAlbumArray : Array of TAlbum;
    TArtistArray : Array of TArtist;
    TSong = record
    Title: String;
    Artist: String;
    Album: String;
    Filename: String
    end;
    TAlbum = record
    Title: String;
    Artist: String;
    Picture: String;
    Path: String;
    Songs: TSongArray;
    end;
    TArtist = record
    Title: String;
    Path: String;
    Albums: TAlbumArray;
    end;
    Not a pointer in site. Use SetLength(open array, Length(openarray)+1) to extend open array by one item, and then openarray[High(openarray)] to set its contents.
    The alternative (and object oriented approach) would be to use TObjectList and create each "record" as an object with associated attributes / methods.
    Dec 2006
    I figured this was dead so I didnt bother posting the solution.
    The problem was this:
    - Every time you resize an array, you create a NEW one, and copy all the information to it.
    - I had pointers to locations in the first array.
    - When I resized the arrays, my pointers were pointing to locations that no longer held the data I needed -- RANDOM NUMBERS
    Thanks though.
    Mar 2006
    Colorado, but Canadian!
    I guess the question becomes... why are you still using Delphi?!
    1.9in x 2.9in -- 47mm x 73mm
    Dec 2006
    I knew somebody would ask that.
    Because I'm good at it.
    Newbie bluescreen25's Avatar
    Apr 2007
    Great develop language... i develop "cAVe"- frontend in delphi.... must not ever be VB....
    regards , bluescreen25
  1. Dual mice and Dual Pointers
    By ThunderStick in forum Input Devices
    Last Post: 06-17-2007, 06:42 PM
  2. Destinator - Delphi
    By deanwarez in forum Software & Software Development
    Last Post: 03-27-2007, 12:34 PM
  3. Delphi programming of XM Direct - Help
    By walttoinfiniti in forum Software & Software Development
    Last Post: 01-18-2007, 09:55 PM
  4. Delphi SDK examples?
    By Nisos in forum FreeDrive
    Last Post: 04-23-2005, 05:22 PM
  5. Delphi +Dlls
    By 0l33l in forum Software & Software Development
    Last Post: 02-06-2005, 03:02 PM
