Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 45
Like Tree1Likes
Thread: Standalone BlueSoleil wrapper
  1. #21
    Feb 2008
    Hi, I also get 770 all the time I click on a button if connected. If disconected it's 771. BlueSoleil itself seems to work. Are there any solutions/suggestions for this problem, yet?
  2. #22
    Maximum Bitrate tempgp's Avatar
    Jun 2007
    New York
    hey lambo I finally goot my heands on your wraper =) good job...
    I was trying to find way to recive SMS messages but dont see this function (and i dont know how wrapper works) to uuse sms as decribed by IVT...
    Can you help me out? I need to listen for new SMS and open and read all new incoming messages + ability to send SMS too.
    I hope you can help me out ;-)
    Waiting for reply
    Acura / Honda A/V CarPC Adapter GA-NET+
    Centrafuse Garmin Mobile PC Skin - GMPC Rebellium Skin
    3D Tuning and Car Visualizer - Preview your car in 3D, change paint job and rims
  3. #23
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by tempgp View Post
    Waiting for reply
    You're correct SMS's are not part of the wrapper as they're not part of the SDK. I have been pestering BS for months about this but no answer so far.
  4. #24
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by lambosprit View Post
    IVT is a b!+ch when it comes to customer service. They do not answer anyone unless your a company selling large volumes (Flux Media) and even then they are still bad about getting back to people. My understanding is that IVT is working on getting SMS to work, but first they are working on echo cancellation then SMS. I think they scheduled it for end of 4th quarter this year, beginning quarter of next year.
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
  5. #25
    Nov 2006
    Been following your wrapper/plugin for a while on and off. I had planned to integrate it into a frontend I was making.
    I have finally got to the stage of programming the phone support and figured I would use your wrapper instead of starting from scratch!
    I have got it to work in my software no problems, although I have a question.
    Do you have a list of available commands that the Commands() function in your dll.
    Answer_Click()
    Hangup_Click()
    Dial_Click()
    GetNetwork_Click()
    SubscriberBut_Click()
    These functions in your sample program have the appropriate variables for Commands(), but what other functions are there and how do I find out what number or letter to put into the Commands() function?
    Thanks!
  6. #26
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by deepgrey View Post
    Answer_Click()
    Hangup_Click()
    Dial_Click()
    GetNetwork_Click()
    Thanks!
    Here are the codes
    case '1': // Answer the incoming call
    case '2': // Reject the incoming call
    case '3': // Please dial with a phone number
    case '4': // Last number redial
    case '5': // Memory dialing
    case '6': // Transmit DTMF
    case '7': // Setting mic volume
    case '8': // Setting speaker volume
    case '9': // N/A
    case 'a': // Request for Current Network Operator Name
    case 'b': // SCO Audio Switching
    case 'c': // Request for Subscriber Info
    case 'd': // N/A
    case 'e': // N/A
    case 'f': // N/A
    case 'g': // N/A
    case 'h': // Check if device is connected
    Some dont work in the version of BSWrapper attached to this thread (I keep forgetting to update it) but do with the mobilephone.net plugin one.
    Commands 3,5,6,7,8 can also have a variable. Its easy to guess what from the bluesoliel sdk documentation.
    Always check the return code as well. Usually a 0 is passed and a 1 is failed.but it can be others. Again check the sdk document for available error codes.
  7. #27
    Nov 2006
    Thanks!
    My phone seems to not report the battery and signal though. I am using the BSwrapper.dll from the RR install. It just returns a little box isntead of a number for both battery and signal.
    I have a winmo 6.5 phone
  8. #28
    Jun 2007
    New York
    for some reason forum did not notifie me of your reply (very sad)
    well if SMS isn not part of BS SDK I guess I will have to go back to my original AT code to get SMS through there and maybe (if thta work) you jsut put reference for my DLL to get full phone controll.... problem is that only one com port canm be opened to the phone
  9. #29
    Jun 2008
    Hi All,
    Sorry to dig up this old(ish) post, but i've been playing with your BSWrapper and I can't find a way to get my app to detect if the connection has been terminated. How have other people done it? I've tried using the command 'h' but this just returns the number 2 all the time independant of whether the connection is valid or not.
    Any help is much appreciated.
    Kind regards,
    James
  10. #30
    lambosprit's Avatar
    Sep 2006
    UK
    I'm assuming by connection you mean phone call
    that one has been a little tricky to do even in the mobilephone.net.
    you need to use the returncallbacks function. (I'm hoping you've looked at the test app i added with the dll)
    to make sure you are in a call you need to check all of the following
    If ReturnCallBacks(BTSDK_HFP_APP_EventCodeEnum.BTSDK_ HFP_EV_OUTGOINGCALL_IND) = "True" _
    Or ReturnCallBacks(BTSDK_HFP_APP_EventCodeEnum.BTSDK_ HFP_EV_RINGING_IND) = "True" _
    Or ReturnCallBacks(BTSDK_HFP_APP_EventCodeEnum.BTSDK_ HFP_EV_ONGOINGCALL_IND) = "True" Then
    then if your not in a call then all of the above will be false
    you may need to get the latest bswrapper from the mobilephone.net thread
  1. Embedding BlueSoleil - I give up
    By rodweb in forum Road Runner
    Last Post: 09-20-2008, 06:13 PM
  2. BlueSoleil 6.2.227.11 Full for Centrafuse
    By Zo6om in forum Centrafuse
    Last Post: 09-08-2008, 08:54 AM
  3. Bluesoleil not licensed
    By halller in forum Centrafuse
    Last Post: 05-06-2008, 08:54 PM
  4. Shuttle to ship standalone XPC motherboards?
    By Defiler in forum General Hardware Discussion
    Last Post: 06-05-2007, 07:42 AM
  5. Replies: 0
    Last Post: 04-06-2005, 12:39 PM
