Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: RR VB.net plugin, need help !
  1. #11
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    ok this may not be proper programming practice (or even work) bu try this.
    Add to your declarations in the RRExtension
    Dim MainForm AsNew Webpage
    and then change you processcommand code as follows
    Code:
      Public Function ProcessCommand(ByRef CMD As String, ByRef frm As Object) As Short
            Dim F As New WebPage
            Select Case LCase(CMD)
                Case "webpage_load"
                    mainform.Show()
                    ProcessCommand = 2
                Case "webpage_yahoo"
                    mainform.WebBrowser1.Navigate("http://www.yahoo.com")
                    ProcessCommand = 2
                Case "webpage_youtube"
                    mainform.WebBrowser1.Navigate("http://www.youtube.com")
                    ProcessCommand = 2
            End Select
        End Function
  2. #12
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    I have the same issue !!!
  3. #13
  4. #14
    May 2008
    Bordeaux, France
    Where can i see that my subs are public ?
    May be like that ?
    Code:
    Public Class WebPage
        Public Sub WebBrowser1_DocumentCompleted(ByVal sender As System.Object, ByVal e As System.Windows.Forms.WebBrowserDocumentCompletedEventArgs) Handles WebBrowser1.DocumentCompleted
            If e.Url.Host = "www.yahoo.com" Then
            End If
            If e.Url.Host = "www.youtube.com" Then
                MsgBox("HELLO WORLD !!!", vbOKOnly, "Info")
            End If
        End Sub
        Public Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
        End Sub
        Public Sub Button2_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button2.Click
        End Sub
        Public Sub WebPage_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
        End Sub
    End Class
  5. #15
  6. #16
    May 2008
    Bordeaux, France
    Same issue !!!
  7. #17
  8. #18
    May 2008
    Bordeaux, France
    This is my full job !
    Attached Files Attached Files
  1. Replies: 6
    Last Post: 03-08-2009, 02:05 PM
  2. Replies: 6
    Last Post: 02-06-2009, 09:32 AM
  3. Replies: 16
    Last Post: 01-02-2006, 08:04 PM
  4. Winamp LCD display plugin / IRMan plugin - together?
    By Jarrod in forum Software & Software Development
    Last Post: 06-03-2002, 06:39 AM
