Results 1 to 10 of 18
Thread: RR VB.net plugin, need help !
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Smile RR VB.net plugin, need help !
    I play with vb.net !
    I have made a Form with a WebBrowser window and two button:
    Code:
    Public Class WebPage
        Private Sub WebBrowser1_DocumentCompleted(ByVal sender As System.Object, ByVal e As System.Windows.Forms.WebBrowserDocumentCompletedEventArgs) Handles WebBrowser1.DocumentCompleted
            If e.Url.Host = "www.yahoo.com" Then
                WebBrowser1.Navigate("http://www.youtube.com")
            End If
            If e.Url.Host = "www.youtube.com" Then
                MsgBox("HELLO WORLD !!!", vbOKOnly, "Info")
            End If
        End Sub
        Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
            WebBrowser1.Navigate("http://www.yahoo.com")
        End Sub
        Private Sub Button2_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button2.Click
        End Sub
        Private Sub WebPage_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
        End Sub
    End Class
    All run well, but i want to replace the two buttons by two RR commands into my RR plugin .
    So, i have tried that:
    Code:
        Public Function ProcessCommand(ByRef CMD As String, ByRef frm As Object) As Short
            Select Case LCase(CMD)
                Case "webpage_load"
                    Dim F As New WebPage
                    F.Show()
                    ProcessCommand = 2
                Case "webpage_yahoo"
                    ProcessCommand = 2
                Case "webpage_youtube"
                    ProcessCommand = 2
            End Select
        End Function
    But i have an issue WebBrowser1 is not defined
    If someone can help me !
    Great thanks
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by Enforcer View Post
    you need to prefix webrowser1 with the name of the form it's on.
    ie
    fmWebbrowser.WebBrowser1
    if the form's name is fmWebbrowser
    and make sure your webbrowser1 object has proper scoping. It should be public because RR's ProcessCommand is public. If its private, friend, public shared etc you will run into object reference problems
    Live mp3Car Facebook Chat
    May 2008
    Bordeaux, France
    But what i must to change in this line please ?
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by pierrotm777 View Post
    Depends on what the name of the form on which the webbrowser1 control is.
    <formname>.WebBrowser1.Navigate("http://www.yahoo.com")
    without the '<' and '>'
    May 2008
    Bordeaux, France
    My form is defined like that:
    Code:
            End If
            End If
        End Sub
        End Sub
        End Sub
        End Sub
    End Class
    so, i try to replace my buttons by this code but without success:
    Code:
                Case "webpage_load"
                    F.Show()
                    ProcessCommand = 2
                    F.WebBrowser1.Navigate("http://www.yahoo.com")
                    ProcessCommand = 2
                    F.WebBrowser1.Navigate("http://www.youtube.com")
                    ProcessCommand = 2
            End Select
        End Function
    May 2008
    Bordeaux, France
    try webpage.webbrowser1
    vb.net don't accept
    May 2008
    Bordeaux, France
    probably have to make the form a friend of the class or vice versa
    I am sorry but i don't understand what you say ! I am very bad with vb !
  1. Replies: 6
    Last Post: 03-08-2009, 02:05 PM
  2. Replies: 6
    Last Post: 02-06-2009, 09:32 AM
  3. Replies: 16
    Last Post: 01-02-2006, 08:04 PM
  4. Winamp LCD display plugin / IRMan plugin - together?
    By Jarrod in forum Software & Software Development
    Last Post: 06-03-2002, 06:39 AM
